Switchcraft enclosed stereo jacks-ring and tip?
Started by Bret608, October 17, 2014, 05:06:48 PM
Hi everyone,
On the enclosed Switchcraft stereo jacks, which is the ring and which is the tip? I've used the mono version successfully but haven't tried this type yet. I know which lug is the sleeve, but the other two look exactly the same and thus aren't easy to work out like on open jacks.
Thanks,
Bret
playpunk
Do you have a multimeter with a continuity setting?
"my legend grows" - playpunk
Sure do! Let me know the procedure and I'll be off and running...
playpunk
I could tell you but I bet if you get a patch cable out you will figure it out pretty quick
That makes sense. Whichever one is the ring will only have continuity to ground if there is a cable plugged in, right?
sounds about right. Usually the lugs are on the opposite site of the actual hook-thingy. The ring is the inner one of the two obviously.
Easiest way is a continuity check with your DMM as mentioned by playpunk. Just contact the hook-thingy (please, someone tell me the english word for that.) and then probe the three lugs till your DMM beeps. that's the one for the ring :)
Thanks, Felix! I know what you mean, even if I am also not sure what the hook-thingy is called.
Actually though, I was wrong that the two non-ground lugs look the same. I inserted a patch cable per Andrew's suggestion and can see that the hook-thingies are contacting different parts of the jack. It's pretty clear which is which; I'll just do the test to confirm.
I need to learn how to read... I completely missed the "enclosed" part :-[
anyhow, maybe you can contact the ring "hook" inside and probe the outside lugs. good luck!
playpunk
The tip will have continuity as will the sleeve
