Mini Amp Build
Started by Guybrush, September 18, 2014, 11:04:08 AM
Guybrush
Hey all
I'd love to have a go at building a mini guitar amp/head akin to the Zvex Nano. Does anyone know of any projects available for such a thing?
Thanks!
thomasha
Hi,
There are a lot of this projects:
Superfly or Murder One or Vibratone from Frequency Central,
http://www.frequencycentral.co.uk/?page_id=11
I build a JCM800 based amp
there are the jj's subminiature amps,
http://www.jjs.at/electronic/class_a_subminiature.html
And there are other amps here:
http://amps.zugster.net/projects/subminiature
take a look here:
http://www.madbeanpedals.com/forum/index.php?topic=248.0
Madbean also has showed some boards, something like a ac4, and another one.
I'm waiting to see those amps, because the board already looks amazing...
You can choose the kind of amp you like and try it in the submini world, like my jcm.
I also have seen a submini champ, and a submini princeton.
The output you can choose between SE for something like 25mW to 250mW or go PP and have almost 1W.
The power supply can be a 12v wall wart, with a SMPS to increase the voltage, or use a real transformer. The high voltage current is very low.
If you need some information, I learned a lot from my builds, and can help you.
Cheers
Thomas
Guybrush
Hey Thomas
Thank you for the detailed reply.
I'll look into you're suggestions and will probably drop you a message to ask a few questions if that's ok?
Thanks again, greatly appreciated!
madbean is also launching a 1W minitube amp sometime this autumn if i remember correctly.
EDIT: didn't see that thomas also mentioned that. sorry
Guybrush
No problem! I'd somehow missed that too.
I'll keep a lookout!
Cheers.
