Doppelgänger
Started by m-Kresol, August 26, 2014, 06:45:23 PM
kothoma
Me likey :) (but then I'm biased.) I really like the city-scape photo!
Thanks guys, your comments and feedback are very much appreciated.
@blearyeyes: it's a decal sealed with envirotex epoxy resin
So, Cody asked for my drilling template, so I'll just as well post it here.
ATTENTION: I used a 1590XX enclosure. If you use a different enclosure, make sure that the relative positions of the drill positions stay the same, eg. by just printing it in the 1590XX size and centering the graphics on your enclosure. I had a small problem with my square switch (I ended up drilling 7mm instead of 6), so make sure it fits! I could have just been me not center punching accurately. In my enclosure the open style jacks were no problem to fit next to the PCB - the closed ones were a really tight fit, just make sure to consider the height of the board.
I used Gimp to make the layout, don't be afraid of the billions of helping lines I used to get all the positions in place. I also included a png and a pdf version. Hope it works.
As always: measure first, remeasure, then drill! Best of luck!
Drilling Template
Quote from: m-Kresol on August 27, 2014, 08:35:20 PM
Drilling Template
Thanks so much, I don't think I have ever stressed this much on a enclosure. I just hate to waste a enclosure due to a miss drill. I seem to always have problems with using open ended 1/4" jacks that are close to PCBs and switches. Thanks again for sharing it.
the template does not include the jacks unfortunately. I just put them were the labels are on the front cover and put them as close to the bottom of the enclosure as possible to make them go over the pcb. since you can rotate the open frame jacks, I think you should be fine.
So is there one deeper?
If you think the Doppelganger is a bit hairy to drill, wait till you try out the Rissole. I deliberately overdrilled on that one.
Cortexturizer
Great work at something that I will never attempt to do I guess. Hard work pays dividends. Cheers
