reverse polarity protection diodes
Started by andywragg, September 07, 2011, 02:02:22 PM
andywragg
HI,
The Chunk Chunk has a 1N4004 as reverse polarity protection. Could I sub this with a 1N4001?
As I see it the difference is the voltage 50v (1N4004) as opposed to 30v (1N4001).
I cant get 1N4004 in UK.
andywragg
bigmufffuzzwizz
Going by what the poster on DIYSB's said, using a 1n4007 would provide enough protection to almost never blow that diode right?
stecykmi
you're not likely to EVER plug something into a pedal that would even come close to what the 4007 can block. it's really excessive.
oldhousescott
Except they're only rated for 1A continuous forward current so you could blow it with a really stout supply hooked up backwards, but most supplies with enough guts will also have some crowbar protection so it shouldn't ever really be an issue.
