Where to get 392k & 422k for Kingslayer / Sunking?
Started by fman7, May 25, 2014, 02:46:02 AM
fman7
Hey,
having trouble sourcing the 392k and 422k resistors for the Kinslayer/Sunking builds.
Can I use 390k and 430k?
thnks
Frank
Generally, within 5% is considered irrelevant because that's the tolerance of a typical carbon film resistor. Along those guidelines, those values should be fine.
Stig
I put two in series to get the correct value. Plus it looks funny:-)
rullywowr
fman7
Thanks for responses, will go for the series option.
Should have mentioned I'm in Australia, so Mouser etc is out of the question.
thnx
Frank
There's also the parallel option, plug in the desired resistance and the % tolerance - the software spits out every possible pair that meet your parameters.
http://www.sengpielaudio.com/calculator-parallel.htm
Stomptown
If your hung up on the values you can always buy a bunch of 390K and 422K and measure the resistance to find a 392K and a 422K. In this case I would go with carbon film 5% tolerance resistors to make it easier. I tried to do it with 1% metal film and it took a while to find a match. Lie mentioned above, it's not really a big deal...
