kingslayer II capacitors
Started by copachino, May 21, 2014, 01:57:18 PM
copachino
hi, as i already been able to pay my Board, im making a small bears shopping for the board, but, i have seen rare capacitor that are not in stock on small bear, this are 5n6, 68n, 390n, and also 422k resistor, also its not listed the 1N5817 diode(i think maybe a 1N400x can work here), can i change this values for the close next??
Some of those capacitors are in stock at smallbear:
http://www.smallbearelec.com/servlet/Detail?no=892
.0056 mf 3932  in stock
.068 mf 4412  in stock
5817 is the same as:
http://www.smallbearelec.com/servlet/Detail?no=509
Don't use a 4001, it will drop the voltage much more.
You can add a 33K in series with a 390K to get the 422K.
The 390nF is a pain in the butt to source. I got some at Mouser. Tayda also has them.
You can definitely get all of these at Mouser, as well.
