Honeydripper (Colorsound Dipthonizer)
Started by Antoy, February 07, 2015, 02:42:08 PM
Antoy
Just finished my build of this crazy device! The pedal is a bit noisy (approximately the same as catalinbread pareidolia for example), but sounds amazing and very unusual. Great chance to try the effect, you could never buy. Thank you, Brian!!!  :)
Nice work on the graphic! Clever with the switch orientation. Do both plugs fully seat?
Antoy
#2
Yes! I think this is the best and probably the only way to place the jack-sockets in the 125b enclosure. There are even 1-2 mms left to the 3pdt-switch. Not my idea. Saw it in someone`s same project in the internet.
Luke51411
#3
Great build! Is the noise you are experiencing kind of hissy? and is it different depending on the vowel sound? I experienced the same thing and found a fix on this forum that I haven't tried yet but it involves decoupling the power supply to all the ICs with a cap. Here is the thread http://www.madbeanpedals.com/forum/index.php?topic=12121.msg109419#msg109419
Hogharry
...and then of course I've got this terrible pain in all the diodes down my left hand side...
Looking super! Like the throat n' tongue graphic.... you're not a surgeon are you...? ;)
brejna
Cortexturizer
Very nice work.  I like the plug for your board power.
Antoy
Luke51411, yeah! the hiss just as described at that post. And also the same behavior in the FX-loop - less noise then before the amp. I think it is just a peculiarity of the circuit and I`m going to left it as is. After all, the noise is not so annoying and barely noticeable in the mix.  :)
cooder, very close! But no! I`m a pathologist (autopsist).  ;D No kidding!
All other, thank you guys! Actually this is my second relatively serious build!
