Components Naughty Fish
Started by Marshall Arts, May 19, 2014, 04:07:57 PM
Marshall Arts
I am currently trying to get the components for a naughty fish, some questions:
The Trimpot should be a Bourns 3362P, right? In the document, it says 2262p (which - I think - does not exist...).
I assume 0.5 W should be enough power rating for the Zener, right?
Thanks for your answers!
Yes to both. I prefer 1w but I believe 1/2w will be okay.
Marshall Arts
Just found a 1.3 Watt 12v Zener and will pick that one.... Thanks!
Marshall Arts
Sorry, another Issue came up:
for the 1n8 cap, I only found this one on my preferred supplier site:
http://www.musikding.de/Styroflex-Kondensator-18nF
It seems to be rather large, would this one be an alternative (it is a 1n5, though...):
http://www.musikding.de/MKP2-15nF-630V
First one should be okay, I think. It's a polystyrene which tend to be small enough at least in a low value like 1n8.
Second one, no. It's 630v.
If you use a different value, go with 2n or 2n2.
Marshall Arts
It took some time, but most of the parts arrived (the madbean-board from the US arrived before the components from Germany ;-)). Some more questions: I compared the ON-ON-ON (actually an ON-Z-ON) switch I received with the one from smallbear (http://www.smallbearelec.com/servlet/Detail?no=1175).
The one I have shortens 2-3 and 4-5 rather than 1-2 and 5-6 like the one from smallbear. So, basically it is "mirrored" in the center position. Will it still work?
Marshall Arts
I found a graphic showing the difference between the smallbear switch and the one I have in this thread:
http://www.madbeanpedals.com/forum/index.php?topic=15592.msg148886#msg148886
Too bad, seems like I really have the wrong one. Looking at the schematic, I assume, that it will not work. Any idea, where I can get the right switch for my project in Germany?!
Marshall Arts
OK, I tested the "naughty fish" with the switch I had and can confirm, that this one does NOT work. So, for all the users, who still want to build one (actually: worth it!): Get the switch from Smallbear as recommended in the documents, or - at least - make sure you get the right type of switch!
Good Luck!
