Dip switch
Started by ckim715, April 24, 2014, 02:06:10 PM
ckim715
So I am currently ordering parts for a KoT clone, and it calls for 2 2 position dip switches; are the dip switches SPST or SPDT? Thanks! :)
-Charlie
Dip switches are (almost) always SPST. You use more switches if you need more throws.
electrosonic
Also even if the schematic shows a SPDT,  sometimes if you are clever you can convert it SPST. i.e. sometimes you can use the SPST to shunt a diode or cap or resistor or whatever to get an equivalent circuit.
Andrew.
These are the ones I just used for my build if you want to go with the DIP switches.
http://www.taydaelectronics.com/dip-switch-2-positions-gold-plated-contacts-top-actuated.html
ckim715
you guys rock, many thanks to all of you!
-Charlie
