125B Fit questions
Started by mattlee0037, May 08, 2014, 05:46:26 PM
mattlee0037
So I know in 125B's you can put the jacks on the top and they will go over the pots, but if the pots are mounted the other way (under the board as in the pork barrel) would the jacks still fit above the PCB or does this not work?
Most of the time it doesn't work. You need to have the PCB be at around 1" from the top end of the enclosure.
mattlee0037
Thanks I'll take that as you are all about the 125B if I remember correctly.
