Tru-oil (was Nuuu)
Started by alanp, April 12, 2014, 04:48:53 AM
Haveyouseenhim, ever tru-oiled a guitar neck? :)
haveyouseenhim
#1
Nope. But it would make a killer finish.
If you try it, try thinning it by half with naptha.
I'm sorry sir, we only have the regular ohms
The guys over at TDPRI use that stuff all the time. I think it's gorgeous. Someday I'll do a parts caster strat with stain & tru oil.
When you say half, you mean literally a 1:1 ratio?
haveyouseenhim
Quote from: jubal81 on April 12, 2014, 06:00:12 AM
Yes. A gun checkerer taught me that. It helps it seep into the grain, and it helps reduce the chances for runs to happen.
atreidesheir
I have tru oil on two guitars and several shotguns.  If you follow directions you should not have trouble with runs.  You never have more than a dab on the cloth at a time.  I have never needed to cut it.  When you let it cure for a month then buff it out with denim and it is ready to rock.  Tru oil is also nontoxic and smells ok.
Quick search of youtube proved fruitful.
Got about 3 coats on the neck at the mo, using paper towels. I've been giving it a quick go with the 0000 synthetic wool between layers.
Haven't started on the body yet, though. That's getting rattlecan satin black.
pryde
I have TO'ed a few guitars that I have built. It is good stuff and pretty easy to work with really. If you are doing a body and want a very durable-thick finish, plan on 25-30 coats. Here are a couple mahogany guitars I built with TO finishing.
rullywowr
That tele....(drool)!
This has a Tru-Oiled neck (and body). It's rather good.
Though it's applied using a different technique...
Got about 5 or 6 coats on the neck, doing a satin black finish on the body.
Should I keep adding more coats? After letting it dry for a few days, the back of the neck feels somewhat rough, certainly not slick. Or should I give it the business with some 0000 synthetic wool?
Mine are wet sanded in, so a different technique. They are smooooth and glidey-like.
pryde
Quote from: alanp on April 15, 2014, 07:20:09 AM
I would do some light wet-sanding with 1000 grit. You have the idea: build 4-5 LIGHT coats then sand back a couple, rinse and repeat. You don't want to lay new coats over "rough" ones underneath so make sure you smooth em a bit.
You could try synthetic 0000 but I don't think its quite aggressive enough
