pre-post boost (dual SHO with effect send)
Started by illcom, December 13, 2013, 10:26:30 PM
illcom
A project i've been working on lately
the signal goes in a SHO first then to an effect send (put your favorite OD here) then effect return then another SHO stage the your amp.
Since putting a boost before your OD will most probably only get you more gain an no volume increase,
I've build this to get more gain and more volume in one pedal click
the two boost are engaged at the same time in a true bypass way by the 2 dpdt relays.
(I know putting a boost before some OD like the zendrive will increase the volume also, put with my Catalinbread clone it only gave me more gain)
By the way the art is a montage I found on google . I've adapted it with The labels but the original image is not mine
catfud
Nice. The artwork looks like an adaptation of the graphics in QOTSA's  Go With The Flow
Concept nicely executed and sounds like a great idea. The graphics look great.
stecykmi
rullywowr
illcom
Thanks everyone,
Quote from: catfud on December 13, 2013, 11:16:07 PM
yeah I took this artwork because its gives me a tone that sounds like qotsa on their song for the deaf album
since I use it mainly with a catalibread SFT.
I think Josh homme used the SHO a lot with his ampeg VT-40 guit amp on this album. I may be wrong on this.
DutchMF
brejna
Nice idea, is there any schematic or layout?  :)
Brane
Bufferz
I like the idea of pre post. Reminds me of a cool circuit I once saw called bliss I think over at revolution duex blog
affiliations: TFX
AntKnee
Is that a waterslide? How did you get the white to pop so much?
Looks great!
upthepunxxx
Super rad!
Wake up and smell the noise!!
