The Hashishian (a familiar multi)
Started by juansolo, January 24, 2014, 04:54:30 PM
I wish Panasonic made the ECQ series in values lower than 10n.  I really like those caps.
Likewise. They fit nicely and look like sweets.
Ettore_M
A multi! You got into 2014 busy!  ;)
Really well done, Juan! The thing I like with this combo is that you can have nothing more in the pedalboard and still achieve a lot of different sounds.  :)
Hector
- Culturejam
GrindCustoms
The name makes me kinky... ;D
Those blonde marocans years....
Quote from: Ettore_M on January 24, 2014, 11:40:44 PM
Hector
I am planning on doing a sister pedal for it at some point as there's not much else I'd want really. It'd have the Klonpressor in there (Lovesqueeze > Klone), plus a distortion and maybe another fuzz (thinking maybe a Rusty Sheriff and a Fuzzmite), might stick a SHO on the end if I can get it all in there... I need to test that that lot will all play together first. But that would essentially get my all my effects in two boxes.
Gledison
hey Juan,
Yep, that decal looks pretty F"£$%^&king nice!
great work and nice combination of effects!
stevie1556
That is amazing inside and out! Looks fantastic!
You always have the most amazing artwork :)
evildead222
OMG this is amazing!!  I love the sleep artwork.  Makes me wanna blast that album right now.
Yeah, looked the album up after I saw the AMAZING art on this.
Heavy as fuck.
Actually... Juan, you need to do a pedal with a hardcore Space Marine on the box, from Warhammer 40k. Or a Techpriest, probably be more appropriate.
Yeah the Dopesmoker art isn't actually that appropriate to what the pedal does, but none of the My Sleeeping Karma album art worked. The Monster Magnet and Hawkwind art I used on two of the others though work as they've been known to dip into the psychedelic from time to time.
W40K stuff could indeed work as a decal at some point *rubs chin*.
Jabulani Jonny
Juan what size enclosure is this?  I'm looking at doing my first multi and I have no idea what size I should be looking at.  My plan will have Bacon Bits -> Brittania -> Cave Dweller -> Rub a Dub.  Thanks!
Jonathan
It's a 1590DD which might be tight... The 1590D is the similar but deeper and about an inch more in every direction is a 1550G.
pedalhealer
www.pedalhealer.com
instagram: pedalhealer_dot_com
