Is there a cheap alternative way to ship overseas in the US?
Started by pappasmurfsharem, March 19, 2014, 04:55:02 PM
pappasmurfsharem
I have a few people interested in PCBs overseas.
Calculating the shipping to the Netherlands from the US is $29 for a small 4oz package. Just for shipping.
I can actually place the PCB order at OSHPark for them, and they will get 3 boards for cheaper than the shipping costs alone.
Is there a better way?
rullywowr
Certainly. You can stick a PCB in a "thank you" or birthday card and ship it first class. Tape it to the card. It will be global first class letter rate ($1.15 I believe) and add 21c for non machinable postage.
DutchMF
Quote from: rullywowr on March 19, 2014, 04:59:05 PM
This method works for sure. I've received several pcb's (and some nice cards!  ;) ) this way, and I'm in the Netherlands as well.
Paul
It also helps if you do what I do, and buy a dozen stamps and drop them off in a postbox, WITHOUT dropping them off at the post shop where they ask stupid questions like "What's in these?"
Stomptown
I recommend buying sheets of the 66 cent stamps (they have a Butterfly on them) for shipping PCB's. You can use one of those in the US to ship the method described above (inside a thank you card) and mark it Non-Machinable (if you just use a forever stamp it will go through the machines). Slap 2 stamps on and you can ship international! Now if you are doing this as a business I would probably mail in flats within the USA. If not, just always make sure you have an extra PCB on hand in case something goes wrong...
Here is a link to the stamps:
https://store.usps.com/store/browse/uspsProductDetailMultiSkuDropDown.jsp?categoryNavIds=catBuyStamps%3asubcatS_S_Sheets&categoryNav=false&navAction=push&navCount=0&productId=S_115904&categoryId=subcatS_S_Sheets
Quote from: pappasmurfsharem on March 19, 2014, 04:55:02 PM
Split the order into two 2oz flats.  As long as you're under 3/4" thickness you're good.  Should be around $3.50 each.
Josh
DutchMF
Quote from: alanp on March 20, 2014, 03:15:56 AM
This is some of the best advice yet, the less hands and eyes go over your envelope/package, the better!!
Paul
Quote from: Stomptown on March 20, 2014, 03:30:40 AM
It's 70c in the US now.
rullywowr
Quote from: midwayfair on March 20, 2014, 06:00:17 PM
Yes it is 70c in the usa now. They just came out with 21c stamps (finally).
Stomptown
Oops! Thanks for the correction and the heads up Jon!
