Daddy Daughter Rehouse D'Lay with Mod and TT
Started by jimilee, February 11, 2014, 02:49:51 AM
This is a rehouse of sorts, it housed the causality that never really sounded right, so tonight I pulled it out and put the Tap Tempo Modulation and D'Lay in here, couldn't let the enclosure go by the wayside. Sounds really clean in contrast to the way it looks, it is literally stuffed in this enclosure completely. The wires started out looking neat and it kind of went south from there. But it works well.
Gledison
Nice paint job! no envirotex to protect it?
it seems that you are getting the delay by the sound traveling through that wires.. :P
Covered in clear coat. I likes it a lot. The long wires were supposed to be routed but it didn't work out that way.
catfud
Cool paintjob - and what better way to spend daddy-daughter time :)
Love the paintjob dude. Very cute!
The wiring.... well at least if you need to make a mod or change you will have plenty of slack left  ;)
