BERMUDA. Triangle Muff w/mids (AION pcb)
Started by Kinki fuzz, February 07, 2014, 07:36:05 AM
Kinki fuzz
Another Big Muff clone, this one built around a aion pcb and with mids control.
I wanted to try this mod, and see if it really helps to have more presence in a live mix, which certainly does. No more disappearing in the mix when you stomp on a big muff, I think it's a great feature to have, specially if you play in a 2 guitar band. Not my case currently, but still feel the difference.
Does it kill the character of the muff? Not as much as I expected when you play alone, and with the band not at all I would say, you hear a muff. So has replaced my beloved ramhead in the board I use with my band!.
The next one I will build is a Green Russian.
Hexjibber
hoodoo
Great build mate, clean as a whistle in and out  :)
Gledison
Very nice design and clean build.
I need to populate mine today and still figuring out what kind of design will be .....will have to have a triangle as well :P
cheers
