Schoon Toon Question
Started by drezdn, February 02, 2014, 08:42:54 PM
drezdn
Is it possible to test a schoon toon before connecting it to another board? If so, how do you do it? Is it as easy as connecting the in and out to the other board together?
Wire it up. Clean signal when true bypass. Then the pot would pan between nothing and buffered clean signal.
