Fat Pants - Motorboat Noise?
Started by playpunk, January 25, 2014, 08:25:01 PM
playpunk
Hello folks.
I just finished putting a fat pants together. I have checked and rechecked the wiring, but I can't figure out what is going on.
My IC Voltages are all OK from what I've seen on other threads, and my JFet voltages look OK too - although on one leg it might be high (18v).
I checked the switch for continuity, and it works. The LED comes on.
It is not boxed yet, and I'm unsure of what is going on. I get nothing good when it's on, or when it's bypassed, just the same motorboat noise.
"my legend grows" - playpunk
playpunk
OK. So the circuit is fine (and tasty sounding)
Here is my question - I was not getting any good noise when I had my cables plugged into the jacks when they weren't in the enclosure. Will I have more luck with those same jacks in the enclosure?
I tested the jacks for continuity, and both are continous between the tip and the solder terminal.
