Transistors, caps, diodes, pots
Started by RickEB, December 27, 2013, 12:28:42 PM
RickEB
Wow!  What a wealth of information. I'm new to the forum and have choose to build a Boneyard and have a couple of questions and wanted to get these straight before purchasing parts.
1) I read in the forum that the lower wattage (1/4watt) make less noise - is this correct?
2) Do all the resistors in the project need to be the same wattage?
3) While picking out pots I noticed they show wattage as well.  Do the pots have to match the wattage of the transistors; or is there a rule of thumb for matching the pots with the transistors?
Any help would be greatly appreciated.
Rick
1) Most PCBs are designed with 1/4 watt resistors in mind. You can also use 1/8 watt with no trouble whatsoever - and no noise.
2) Nope.
3) No matching. Your main concern here, again, is the size. you just want to get what will fit in a stomp box. By far the most common pot is the 16MM Alpha.
If you're unsure about what to source, you can always start with a full kit from BYOC.
muddyfox
I'd just add to watch your pot tapers. There are no absolute rights or wrongs here but it may just help the user experience with the finished product.
