Any love for presensitsed/photosensitive PCBs?
Started by Ettore_M, November 24, 2013, 11:17:17 AM
Ettore_M
Quote from: Gledison on November 24, 2013, 10:23:54 PM
hey Hector. im still using the annoying tonetransfer method. in my case, I have no much place for an extra UV lamp.
look, do you add a solder mask on your boards?
cheers
No, I don't. I would, but it was quite expensive to buy. Maybe in the future!
Hector
- Culturejam
haveyouseenhim
Where do you guys buy the photo boards? I would like to try em.
I'm sorry sir, we only have the regular ohms
angrykoko
I use the photosensitive stuff too, easy as pie.  The most expensive part (for me) is the transpancy stuff for inkjet printers.
Warming the ferric chloride made the biggest difference for me getting really great etches.
The early bird may get the worm, but the second mouse gets the cheese in the trap.
Stomptown
I don't know if I would have boards fabbed for me, because as I said, I got into this, because I love DIYing.
It seems like a lot of people feel this way! I personally love the feeling of getting my own board fabbed and it still feels like DIY to me, because in the end, I did the PCB design myself. I also feel a lot more confident about the quality of my builds when they are on fabbed PCB's. With etched boards I always wonder how long it will work for. Most likely a very long time, but that question always looms for me. I do love etching my enclosures though and having etches a good number of PCB's I definitely respect those who do it!
Ettore_M
Quote from: haveyouseenhim on November 25, 2013, 12:57:11 AM
Mike, I buy them locally, so I don't know any online shop. But if anyone knows where to get reasonably-priced boards, please tell us.
Quote from: angrykoko on November 25, 2013, 01:25:17 AM
Exactly. You couldn't have been more spot on! Indeed, the transparencies are quite expensive. Something like $0.70 -$0.80 per sheet here in Greece.
And indeed, warm ferric chloride is pretty essential. Also, developing your board really well is an important step.
Hector
- Culturejam
Ettore_M
Quote from: Stomptown on November 25, 2013, 04:28:18 AM
That's a quote from me, but nevermind!  :D
Yes, I know what you mean. Of course, the design is yours and getting fabbed boards in your pedals makes a huge difference (at least for the customer, if there is one). But for me, I want the end product to be a result of my own making, as far as I can. But then again, I can't insist of that, because I have never used fabbed boards in a pedal of mine. At the moment, it's an extra expense and I can't afford it.  ;)
Hector
- Culturejam
Gledison
Quote from: Ettore_M on November 24, 2013, 11:15:52 PM
cheers
Hector
Im using a UV curable paint! It works pretty well! I posted a thread here on how to use it if u are interested...
Cheers
rullywowr
This. I feel exactly the same!  Having your own boards made still feels DIY to me plus you have the advantage of sharing what you made easily. Once a board is good to go its a matter of "how many would you like". :)
Also, warming up my hydrogen peroxide/muriatic acid etching solution works very well. I usually etch in a small plastic container and float it in a slightly larger container filled with hot water. The heat speeds up the etching process significantly.
Gledison
Quote from: rullywowr on November 25, 2013, 12:58:32 PM
Hey,
I do the same with ferric chloride! It etches quite quick using hot water as a warming bath!
Mike recently had the same discussion on another forum. Small Bear has the boards plus...
Quote from: daventCircuit Specialists also sell the MG Chemicals Developer where Small Bear points you to the lye route.
Amazon is another source for boards and developer AND free shipping on orders over $25.
http://www.amazon.com/MG-Chemicals-Positive-Developer-Liquid/dp/B005T8QLCY
Mouser shows the developer for US addresses, Allied show it, haven't found it at Digikey.
Google gives a bunch of sources. https://www.google.ca/search?q=mg+chemicals+positive+developer&oq=mg+chemicals+deve&aqs=chrome.3.69i57j0l3.19057j0&sourceid=chrome&ie=UTF-8
If you're in Canada and need to mail order developer Electrosonic is one source.
http://www.e-sonic.com/acc/products.aspx?partID=418-500ML&partIDExt=281&command=detail
A few more photo pcb's for tube and solid state projects. 2oz and 1oz boards. My toner transfer attempts at best were pitted with ragged edges to the etched traces, very nasty, ugly, ugly, ugly... but they did work.
A very good tutorial on this process:
https://www.smallbearelec.com/HowTos/PhotoPCBoards/PhotoPCBoards.htm
Some links for materials:
http://www.smallbearelec.com/servlet/Detail?no=1065
http://www.ebay.com/itm/5pc-Photo-coat-One-Side-Fibre-10x15-PCB-w-Accessories-U30-/380699549902?pt=LH_DefaultDomain_0&hash=item58a37620ce
http://www.circuitspecialists.com/printed-circuit-board-fabrication
https://www.acehomecenters.net/products/acid-muriatic-qt%7C12786.html
Ettore_M
That are some nice links you got there, Dave. Thanks! :)
Hector
- Culturejam
