4 builds & 1 re-decal
Started by juansolo, November 13, 2013, 09:05:38 PM
stevewire
Hey Juan,
Excellent work.  Love the look of the Small Clone.  I've been thinking about the Emma Reezafratzitz.  Now seeing that you built the Reezafratzitz, I'll have to give it a try soon.
Sibob
Very cool builds.
I'm not familiar with the Optical Bypass boards you're using (I can see they're 1776 Effects).  What are the thoughts/pros etc of Optical Bypass? Is it along the same lines as a relay?
Cheers
Si
Pluses of the Optotron.
- No pop
- More robust stomp
- Easier/neater wiring
- Still grounds the effect
Downside
- Relatively expensive
For me the plusses far outweigh the cost aspect and it's all I use now.
The only time I use 3PDT is when I have no other choice. In the UK you can't get decent ones anyhow and I've had a few reliability issues with the Chinese ones from Tayda.
croquet hoop
Awesome builds, I particularly like the Small Clone. You piqued my curiosity about the Reezathing too.
I see that you've used these open frame Kobiconn jacks in a few builds lately, do they feel as sturdy as Switchcraft/Neutrik jacks?
They seem to be and when we've used up our stash of open jacks, they'll be what we use instead. The only reason I used them in that build was that I planned to use enclosed jacks (hence low-pro components on the board and it's mounted quite high up), then completely forgot about that and drilled the holes where we'd normally put open jacks in. So neither open or the enclosed jacks fitted. Thankfully the new ones are tiny!
croquet hoop
Rockhorst
Quote from: juansolo on November 13, 2013, 09:05:38 PM
Banana?
An Emma Reezafratzitz clone built on a THN Technik board fabbed by Haberdasher. Really good distortion this one. I'm surprised it's not built more.
Why minions? Why Reezafratzitz...?
Clearly, all knobs should've been labelled BANANA
LOL. It'd be impossible to use, but awesome.
