Cave dweller debug help
Started by otsismi, October 06, 2013, 05:08:16 PM
otsismi
Been troubleshooting a cave dweller I built the other day. I'm getting very low guitar signal through the effect but no delay. Pots do nothing except raise and lower volume somewhat.
Using an audio probe I followed the signal from the input to LPF1-in on the pt2399, from there I can't find the signal anymore. LPF1-out does not have a signal. Is the chip fried? Maybe a solder bridge to ground? I've inspected the board extensively and can't find anything visible.
Help!
Can you remove the IC and get audio? Delays I believe are the only ones you can do that with. Also have you tried different chips? Is your soldering good? What are your voltages.
otsismi
