DoubleFlush Tremolo
Started by Gyrofist, January 31, 2011, 03:45:48 PM
Gyrofist
Would it be a stereo or a mono jack for the in/out of the DoubleFlush?
irmcdermott
Depends on if you are putting a battery in it. If you are, stereo on the input, mono on the out. If you are not going to use a battery, then a mono on both will work.
Gyrofist
Okay, makes sense. I'm not all that experienced with this whole thing, so I wasn't too sure. Figured I'd ask before ordering.
irmcdermott
No problem! Feel free to ask any other questions.
Gyrofist
What would the polarity of the Double Flush's power jack be? Should the adaptor have a negative or positive centre? i.e., would it be (-) --(.--(+), or would it be (+) --(.--(-) ? I made the mistake of using the wrong polarity on my wah pedal and killed some of the components and I don't want to go and do that after spending so much on parts.
The double flush uses -9v like most boss standard pedals. Use the layout described in the wiring diagrams and youll be fine. Post more specific questions if you need more help.
