Data Sheet help - 18V Supply Voltage
Started by Chi_Boy, July 28, 2013, 08:21:28 PM
Chi_Boy
Hey guys,
I'm pretty sure I'm over thinking this, but I read something on the forum and it's biasing my judgment.
I have a JRC4580/NJM4580 and I want to supply it with 18V instead of the usual 9V.
The data sheet says +18V/-18V for the supply, but that's for a dual rail supply, so straight 18V like we use is fine, right?
I've never run anything at 18V, so I just want to be sure.
This is the datasheet: http://www.mouser.com/ds/2/294/NJM4580_E-218114.pdf
Thanks,
George
ThePastRecedes
Make sure the capacitors are sufficiently rated too.
I build stuff for myself, sometimes I do 1 offs, I label them as HornBlende Audio.
oldhousescott
Yes, 18v single ended is fine. As TPR states, make sure your caps are rated at least 25v.
