help mudbunny civil war issue problem found yeah.......
Started by glout, August 03, 2013, 12:57:57 AM
glout
I made the mudbunny civil war version and used the 2059 instead of the 2058 and now when i roll back sustain it grits bad and as i go further back i loose signal completely
When i roll up sustain past 1/3 it works fine till end.
Is the use of 2059 need resistor or cap change that is the question.
Was a solder splash on top of board.
Bob
