Quick Snarkdoodle question
Started by drezdn, July 02, 2013, 06:01:26 PM
drezdn
When building the Snarkdoodle to the Craig Anderton specs... Should I jumper R1, or just leave it empty there?
omit = leave it out.
jumper = um, jumper. :)
Edit: Should add a little bit of learning here. What, in your opinion based on the schematic, would happen if you made R1 a jumper?
drezdn
Thanks!
There would be a connection to ground really really close to the input? Which I'm guessing would make the pedal not work?
Quote from: drezdn on July 02, 2013, 09:11:03 PM
Thanks!
Exactly.
