omitting the charge pump on the Kingslayer
Started by MarkL, June 17, 2013, 09:28:12 PM
MarkL
I am having trouble sourcing the proper Max1044scpa or TC1044scpa charge pumps for this project.  Is there a way to effectively omit the use of the charge pump and still have the circuit work (though I know this will affect headroom)?
Ground is the bias voltage for the op amps (rather than 4.5v virtual ground, so you might run into problems. Where are you located? Tayda ships all over the world and sells the 1044.
Quote from: midwayfair on June 17, 2013, 11:37:09 PM
Its the S thats important
Tayda only has the CPA, not SCPA version to my knowledge
Actually, the MAX chip has no "S" designation it turns out. So, your choices are the MAX1044CPA, TC1044SCPA or ICL7660SCPA.
Quote from: LaceSensor on June 19, 2013, 03:05:44 PM
Are you sure that's true of the MAX? Thought it only applied to the 7660.
edit, beaten by bean by a second.
RobA
I haven't actually tried the MAX1044CPA yet, but the spec sheet says it has a frequency of 5kHz with a boost of 6 times. That should work. In fact, it would make it better than any of the other 1044SCPA types I've tested. I've just added couple to my Tayda cart waiting for the next order.
talking rubbish again as usual. sorry gang. My mistake. I have a load of max chips never used cos they just said CPA and I figured theyd be unusable. Score me, and my ignorance (!)
