Projects => Tech Help - Projects Page => Topic started by: Dr. Pirateface on February 19, 2013, 10:17:28 PM
Title: V3207/V3102 Pork Barrel - No/Low Effect
Post by: Dr. Pirateface on February 19, 2013, 10:17:28 PM
Hello, gentlemen. This is my first post on this forum, and I read the rules, so please excuse any accidental breaches of protocol or etiquette.
Circuit:
Pork Barrel Chorus (latest version)
Configuration:
Issue:
I am getting an essentially clean signal through the pedal. I say essentially because if you listen very closely and intently, the engaged effect sounds very slightly different from the bypass. The LFO LED works fine, and changes brightness and blink rate with the DEPTH and RATE knobs, respectively. The knobs do not, however, effect the output signal in any appreciable way.
Diagnostic Findings:
I will post component voltages as soon as I can. There don't seem to be a lot of threads concerning V3207 Pork Barrels, so I have no basis for comparison. Now, I know the issue is probably something stupid I did. I fully realize that in vero-boarding this circuit I've brought this upon myself and made it nigh impossible to troubleshoot. Any advice or insight you can offer would be much appreciated. Thanks, and rock on!
Title: Re: V3207/V3102 Pork Barrel - No/Low Effect
Post by: bryanrichie on July 16, 2013, 12:34:04 AM
I seem to be having the same problem with the same configuration, did you find a solution?
BR
Post by: Scruffie on July 16, 2013, 12:43:38 AM
Post voltages for your build.
