Projects => General Questions => Mods => Topic started by: jeffaroo on November 23, 2012, 01:48:48 AM
Title: EGO
Post by: jeffaroo on November 23, 2012, 01:48:48 AM
the 2 leds used for clipping...do they stay on or flash? do they turn on and off with the bypass?
i wanted to try to incorperate them into the case if i could
make a pic and leds will be eyes (balls...etc)
Title: Re: EGO
Post by: madbean on November 23, 2012, 02:34:36 AM
They will light up when you have them selected with the switch and only when the effect is engaged---not in bypass. So, you can wire them off-board and mount them to the enclosure just like you are wanting.
Title: Re: EGO
Post by: oldhousescott on November 23, 2012, 03:05:23 AM
...and only with signal applied. When you play, they should light. When you stop, they should go out.
