I'd love to do a good buffer/splitter/mixer. mainly for running delays and reverbs in parallel. something pedalboard sized like RJM music's mini line mixer but with 3-4 "send switches" for different channels.
I'm thinking it should have an input>buffer/split>have a dry through channel with a level control> and a switch for each effect channel> return for each and corresponding level pot.
maybe it could have mono in and switchable mono/stereo out. something for phase reversal.
when I had a rack setup, I used a 16 mono channel/ 8 stereo channel mixer with a few different delay units(tc electronic - gforce, d-two, strymon brigadere and elcap.) all running in stereo. I think delays sound so much more natural and spacious like that (if thats your thing). A panner control might be a cool addition too.
I've missed using parallel verb and delay since gutting my rack. It would be great if that could be stuffed into a smallish footprint, a 1590bb is probably pushing it with all those jacks and switches. one of those larger trapezoidal boxes might be big enough without getting clumsy.
Yes, this is a good idea.
Cool idea. You could use a 3-way switch on each effect for A/B/A+B. Also, if you're making all those buffers, maybe add one or two more for a tuner out or balanced xlr.
+1 the pigtronix keymaster could be a source of inspiration
This is a really cool idea.
I would love to see a re-amper project somehow combined with this as well (maybe combine with this idea).
That way I can run my DAW tracks through lovely analogue treatments, and not use damn plugins all the time!
Like jtn says; the keymaster could be a cool source of inspiration.
Quote from: jtn191 on February 29, 2012, 05:22:37 PM
yeah something like that but at least 3 switchable channels(I'm thinkin 2 delays and reverb)
i designed something like this for doing stereo trails bypass with delays and reverbs. I'll see if I can find it tonight. I think I used 4066 switches, but it could easily be swapped out for relays, etc.
Here's what I've been working on for a stereo trails looper/mixer. At some point I used the 3rd unused switch to add in a mono channel that can be panned between the two outputs. My plan was to put a stereo reverb in the main loop and a mono delay in the panning channel. I lost that schematic in the flood, but I'll get back to it at some point.
I realize this isn't the same as the line mixer requested, but maybe it can help you get somewhere with it.
Hi folks.
Interesting idea this splitter/buffer mixer. Not only for running delays and reverbs in paralell, also for switching from one to another chain of effects, using 2 amps, mixing clean sound with a chain of effects, or even mixing several chain of effects.
Did you read the "parallellizer" article in ggg, in the buffer/routing section? really inspirational.
I´m tinking in an A/B/AB box, after that, two more A/B/AB boxes. So we can get 4 channels (with 6 footswitches). A lot of footswitches, but this way, the box could be extremely usefull, because you can change to any combination of the channels with only one push.
After that could be a buffer switched by an spdt for each channel, the chain effects loop, and one more switch each channel for reverse phase. Finally the mixer with pots, and maybe a routing mod for two outputs in order to use 2 amps.
Really nice thread this one...
yeah that article and the mini mixer was what got me going on this. I have a prototype frankensteined together with 3 channels 2 of which are switchable. I got sidetracked but it shouldn't take too long to finish it. I'm sure brian could put something together that would be far more elegant thought.
hehehe I was just etching the ggg mini-mixer PCB, when read your lines. I´m going on with the project.
It could be nice to upload some pictures of the finished boxes.
a couple line/instrument level switches on would also be helpful for helping pedals deal with different types of effects loops or line level processors.
