Projects => Tech Help - Projects Page => Topic started by: freshmex18 on October 09, 2023, 05:39:13 AM
Title: Tourbus Troubles (the bus burned down)
Post by: freshmex18 on October 09, 2023, 05:39:13 AM
Had a working Tourbus pedal.  Been a few months since I used it.  Built a new pedalboard.  Plugged it into the same 18V plug on the OneSpot power supply on the new board.  Noticed the pedal ticking in bypass.  Opened it up to take a look and adjust the trimmers to see if I could get the ticking to stop.  After a while, a tiny puff of smoke from the region of the 4047 IC.  Panic ensues.  Cut the power.  Removed daughterboard.  Could not confirm the origin of the smoke.  Replaced all of the components in the immediate area of the 4047 including the IC.  Reflowed all connections on main board.  Pedal is not powering up.
How should I proceed?  Is there troubleshooting to be done or does smoke = trash the bus and start again on a new board?
Title: Re: Tourbus Troubles (the bus burned down)
Post by: jimilee on October 09, 2023, 03:42:27 PM
How does D1 look and can you post your voltages?
Post by: freshmex18 on October 09, 2023, 09:25:13 PM
Diodes seem fine
IC1
9.10
5.38
4.94
3.24
4.94
5.35
9.14
17.44
IC2
2.06
0.6
0.6
3.23
6.54
0.27
11.71
2.87
2.88
11.78
0.82
6.21
17.44
0.59
0.59
2.15
IC3
9.44
6.26
5.71
3.57
5.71
6.22
9.14
17.43
IC4
9.68
1.25
1.16
1.97
1.24
1.17
9.69
17.42
IC5
8.44
8.55
0.61
17.42
17.41
17.40
1.97
1.97
1.97
5.80
5.79
1.96
6.12
17.42
IC6
9.23
7.93
7.87
5.67
7.87
9.96
9.21
17.41
IC7
17.42
5.65
0.04
0.05
1.99
5.65
0.02
0.13
IC8
9.19
7.00
6.50
5.68
8.15
8.35
9.19
17.41
IC9
17.42
5.65
0.04
0.04
1.99
5.65
9.20
0.18
Post by: madbean on October 09, 2023, 09:44:21 PM
Something is obviously very off. Your voltages don't resemble the voltages listed in the build doc in any way. So, something is wrong with the power supply area or perhaps with how you measured the voltages on your build.
Post by: freshmex18 on October 09, 2023, 11:10:57 PM
Is there a different procedure for reading voltages on a positive ground circuit like the Tourbus that I am not aware of?
Post by: madbean on October 09, 2023, 11:41:57 PM
Quote from: freshmex18 on October 09, 2023, 11:10:57 PM
No, your black lead should still be connected to ground and your red lead is what you will use to measure voltages. In the case of the Tourbus, you should read negative voltages all around because it is a positive ground circuit (so 0vDC is the highest voltage reading you should see as opposed to the lowest on a single supply negative ground circuit).
For example, on IC1 pin 4 should be about -15v (which is the supply voltage) and pin8 should be 0v (which is still ground).
Post by: madbean on October 09, 2023, 11:53:08 PM
To make this process easier, try this:
Remove the daughter board. Now remove all the ICs on the main board except IC1. Power up the board again and record the voltages on the 8 pins of IC1. List those here and then we'll move onto step 2.
Post by: freshmex18 on October 10, 2023, 12:31:32 AM
I have the very first version of the circuitboard.  Is there anything different about that board with the documentation on the site vs the current version?  The current documentation shows DC In connected to the long terminal of the DC jack and Ground connected to the short terminal and that is what i have currently.  I did disconnect those wires when troubleshooting and reconnected them as per the current documentation
Post by: freshmex18 on October 10, 2023, 12:41:43 AM
With daughterboard and all ICs but IC1 removed
IC1
9.15
2.21
0.62
1.09
0.61
2.22
8.87
17.42
Post by: freshmex18 on October 14, 2023, 04:48:40 AM
Hello?  Anyone still here?
I reflowed all of the connections again and got a new, better multimeter.  Whichever it was that helped, here are the new readings with the daughterboard and all ICs but IC1 removed
IC1
-0.582
-1.67
-1.741
-1.151
-0.888
-0.521
-0.473
0.0
Post by: madbean on October 15, 2023, 07:50:56 PM
Something is still not right there. Let's try this:
Take DC voltage readings here:
Both sides of D1. Cathode side should be about -18v and anode side should be a little less.
Output leg of the LM7815 regulator. Should be about -15v.
Post by: freshmex18 on October 15, 2023, 08:06:02 PM
D1
Cathode -17.64
Anode -17.36
Output leg of regulator
-15.67
Post by: madbean on October 15, 2023, 11:22:01 PM
That's perfect! So, we've narrowed it down. The issue seems to be on the VC power rail. Since one end of R38 is connected to the output leg of the regulator, and we have -15.67 there we know power is getting out. So, let's take the voltage reading on the other end of R38. That's the VC rail which powers IC1, where we are getting a wrong reading on your build. Looking at R38 on the PCB, it's oriented vertically. You want the reading on the top pad. The bottom pad is the one that should already read -15.67v.
Also, verify you've got 10 Ohm in R38 and that C37 is oriented the right way on the PCB.
Post by: freshmex18 on October 16, 2023, 12:26:49 AM
So both of those parts are ones that I replaced as possible causes of the smoking.
And you called it.  Somehow, I replaced the 10R with a 330k.  I have no idea how I even did that.
R38 was reading -1.153 on the top pad with the 330k.
R38 now reads -15.56 on the top pad
C37 is correctly oriented
IC 1 now reads
-7.83
-7.83
-7.79
-15.56
-7.75
-7.83
-7.84
0.0
Post by: madbean on October 16, 2023, 01:01:04 AM
You nailed it!
Post by: freshmex18 on October 16, 2023, 01:03:52 AM
So next step is to replace everything and see if it works?
Post by: madbean on October 16, 2023, 01:12:07 AM
Quote from: freshmex18 on October 16, 2023, 01:03:52 AM
More or less. I would leod in your ICs on the main board first, then spot check voltages to see if you retain -15v on the power pins of the ICs. If so, load up the BBD board and just follow the build guide. So long as there isnt another issue we overlooked you should be good to go.
Post by: freshmex18 on October 16, 2023, 04:17:07 AM
Success!
Pedal is working again!  Thank you so much for the one-on-one troubleshooting.  It is greatly appreciated.  Such a high level of customer service around here.
So I was right that one of the components in the area of the BBD was at fault after the pedal went up in smoke (it wasn't really that much).  Replacing the lot of them did remove the faulty component.  It was my error of putting a 330k resistor in place of the 10r that kept the pedal from turning on and working afterward.  I still have absolutely no idea how I cocked that up.  Did I somehow look up R23's value instead of R38?  Did I accidentally put a 330k in the 10r bag during a previous build?  Who knows.  Totally my fault
And the best part is that the new BBD has eliminated the ticking in bypass.  For now at least.  Here is hoping it stays that way.  For now, everything is working as it should.
Thank you again.  This is why I keep coming back for more boards.  Happy to support you
Post by: madbean on October 16, 2023, 02:25:57 PM
I'm glad it worked out. Most problems like these can be solved pretty easily just by breaking things down in the right way. The only trick is to know where to start!
Post by: gordo on October 16, 2023, 03:02:41 PM
NICE!!!
