General => Open Discussion => Topic started by: LaceSensor on June 27, 2023, 09:09:45 AM
Title: Anyone here mod guitars? Wierd ground issue
Post by: LaceSensor on June 27, 2023, 09:09:45 AM
Hi all
Just incase anyone here messes with guitars
I have a Squier Paranormal telecaster thinline with the jazzmaster pickups
I swapped the stock units out for Pure Vintage 65s and replaced the switch, and pots (CTS)
Also I added copper shielding tape all around
Now the issue I get is when I have it plugged in when I touch any metal work, it creates a static "pop" type sound
To me this is a grounding issue but I cannot figure it out
Ive had the guitar apart 3 times, rewired it, changed the switch
The only thing I havent done is change the pots again which I could. process of elimination I guess
Im loathed to beleive the pickups are "bad" inherently but I guess that could be a thing
Note, Ive tried other amp, cables etc.
Any ideas?
Title: Re: Anyone here mod guitars? Wierd ground issue
Post by: madbean on June 27, 2023, 11:28:36 AM
Did you try checking for ground continuity between pots and the bridge hardware?
I wonder if the new pickups might be microphonic somehow.
Post by: LaceSensor on June 27, 2023, 12:01:33 PM
Quote from: madbean on June 27, 2023, 11:28:36 AM
Yes I replaced the bridge ground. There is continuity
Ive also just removed the pots (wired the hot directly to the output) and its doing the same, annoyingly
its so wierd.
Post by: LaceSensor on June 27, 2023, 02:51:25 PM
after taking everything apart and re-doing everything I can only conclude there must have been an earth loop somewhere.
Ive added another ground between the pots and the "body" (being copper foil shielded...)
Annoyingly it was even doing it with just one pickup, straight to the out jack with the bridge ground earthed at the output jack too. Super wierd.
Post by: gordo on June 27, 2023, 11:12:56 PM
There's this weird thing that happens to some tele's and it's nicknamed black-guard disease.  Has something to do with the old style guard building up static.  When I built one I troubleshot it till I was half crazy (well, ok, half more crazy) and the only thing that fixed it was removing the cover to the neck pickup.  Ironically the neck pickup sounds so much better that I'd recommend it anyway but I never got resolution beyond that.  This was with a really nice set of Seymour Duncan pickups and all top shelf pots/switch/jack.
Post by: madbean on June 27, 2023, 11:17:38 PM
Quote from: gordo on June 27, 2023, 11:12:56 PM
My buddy Graham has a custom shop Tele with a highly microphonic bridge pickup and it is a frigging rock and roll machine. It's so on the edge of being out of control with fuzz and distortion I don't think he'll ever get that pup fixed 😆
Post by: LaceSensor on June 27, 2023, 11:37:58 PM
Note, it occured with the stock pickups too, as I put one back in to rule that out. So I dont think it was a pickup microphonic issue.
Super wierd....
Post by: lars on June 28, 2023, 11:30:36 PM
To get a better idea of what you're dealing with, is this pretty much the guitar you have? (I realize there are several color options).
(https://i.postimg.cc/SNddt9bY/squier.png)
If it is, then the pickguard really has no bearing on grounding or shielding, so that's irrelevant, and the control cavity doesn't have the typical telecaster metal panel that the pots and switch are mounted to. I'm guessing the wiring/grounding is more like a Les Paul than a typical Tele. That changes things, and is a key piece to know before moving forward.
Post by: LaceSensor on July 02, 2023, 04:16:02 PM
Quote from: lars on June 28, 2023, 11:30:36 PM
thats the exact model down to the colour, yes.
Post by: Aentons on July 02, 2023, 05:03:50 PM
So are you saying that you wired two different sets of pickups straight to the output jack and the popping still happens with both sets? If that's the case, it doesn't seem like the issue is in the guitar at all.
Post by: LaceSensor on July 02, 2023, 09:16:40 PM
Quote from: Aentons on July 02, 2023, 05:03:50 PM
well, theyre in the guitar and I did resolve it with a body grounding solution, so I think it was in the guitar so to speak.
Post by: gordo on July 02, 2023, 10:52:46 PM
Lovely guitar and glad you got it sorted out!
Post by: Aentons on July 03, 2023, 08:36:26 PM
Quote from: LaceSensor on July 02, 2023, 09:16:40 PM
Ok, sorry, I did not realize you resolved it.
Post by: LaceSensor on July 08, 2023, 11:20:40 PM
pretty interesting right here
https://www.youtube.com/watch?v=SQU85rklIgQ
Post by: lars on July 09, 2023, 01:57:51 AM
Quote from: LaceSensor on July 02, 2023, 04:16:02 PM
Glad you got it sorted out. Grounding issues in guitars are bizarre and fraught with gremlins that don't follow the "rules".
Post by: flanagan0718 on August 07, 2023, 01:35:59 PM
Glad you solved the issue. I've worked on lots of guitars and trouble shot SO many issues while working at fishman. Of course those were active pickups but I always follow the same 3 steps when I start.
- Check all grounding in guitar, even the bridge ground! Must have a bridge ground even with active electronics. Think of it as a safety net.
-Double and triple check switch wiring. Also do tap test and check coil tapping and other option if applicable
- Try a different test cable and amp...just in case. Then return step 1
Those seem pretty basic but most of the time I found the issue to be in the grounding or the optional wiring.
Also 5 way switches are the bane of my existence!! Lolz
Post by: LaceSensor on August 07, 2023, 10:23:12 PM
Ironically,  I just gutted and did some fancy wiring on a very cheap strat copy, with super 4p5t switching, coil tapping, series/paralleling and have literally zero issues. And yet, this 2 pickup single toggle was a bear.
