Projects => General Questions => Topic started by: beneharris on June 02, 2023, 02:57:57 AM
Title: ZVEX Super Duper - Diag help
Post by: beneharris on June 02, 2023, 02:57:57 AM
Hi guys, I'm stumped.
First off, here is the schematic that is closest to what I have here:
https://www.pcbway.com/project/shareproject/ZVEX_Super_Duper_2_in_1.html
One transistor is just not biasing properly.
Side 1 is the one I am having issues with. It is sputtering like it is starved for voltage - which as you'll see, it is. I have pulled all the resistors up near it and they have all measured fine. I thought maybe the transistor had failed, so I replaced it, and the voltages are the same.
Here are the voltages I am getting. They are taken with the gain controls (C5K) down:
Side 1
D - 4.8v
G - 1.64v
S - 4.1v
Side 2
D - 7.2v
G - 2.69v
S - 1.83v
I have 9 volts at the front side of both 5k1 resistors, but then the voltage drop across the 5k1 resistors coming from the power rail is:
Side 1 - 4.33v
Side 2 - 1.93v
I have tested the diodes and they seem to have a reasonable voltage drop across all of them.
It is just not making any sense to me. What else could be causing this voltage discrepancy.
Title: Re: ZVEX Super Duper - Diag help
Post by: mauman on June 02, 2023, 03:27:00 AM
I think we need some photos of your build.  Is this a PCB?  Vero?  Perf board?  There's definitely a problem with the power/bias for Q1.
Post by: beneharris on June 02, 2023, 05:00:30 AM
Quote from: mauman on June 02, 2023, 03:27:00 AM
It is an original pedal. Nevermind the resistor on the back of the board, it doesn't go there. It's a pita to get it where it goes, so for testing I slapped it on back.
I'm doing this from my phone, so if the link doesn't work I'll upload them when I get to work in the morning. Home system is shut down for the night.
https://imgur.com/a/twHHJX8
Post by: Govmnt_Lacky on June 02, 2023, 12:20:17 PM
Are the transistors installed properly? According to the silkscreen, it looks like they are reversed. (No idea if you substituted)
Post by: beneharris on June 02, 2023, 03:20:43 PM
I thought that too, but that's how they were when I opened it up. I only ever pulled the one out. And the one I didn't pull, that is the side that works fine.
Post by: Govmnt_Lacky on June 02, 2023, 03:45:32 PM
Quote from: beneharris on June 02, 2023, 03:20:43 PM
Might be worth another look when compared to the transistors installed and the schematic.
Post by: beneharris on June 02, 2023, 04:20:26 PM
Quote from: Govmnt_Lacky on June 02, 2023, 03:45:32 PM
I'll definitely double check it. But a week or two ago when I ordered new transistors I remember checking the pinout and it was correct, but the silk screen was wrong.
I'm about ready to breadboard this and see if I can duplicate the issue. I know I'm missing something stupid.
Post by: beneharris on June 02, 2023, 04:28:24 PM
I found this talkbass for sale post and it's got a gut shot, and the transistors are installed the same direction.
https://www.talkbass.com/threads/zvex-super-duper-2-in-1-sa-special-edition.1411791/
Post by: Govmnt_Lacky on June 02, 2023, 04:46:20 PM
Quote from: beneharris on June 02, 2023, 04:28:24 PM
I see one picture of the guts and I cannot tell which direction they are in. Regardless, it only takes a second to verify if they are in correctly by using a pinout and the schematic.
Post by: beneharris on June 02, 2023, 05:11:47 PM
Quote from: Govmnt_Lacky on June 02, 2023, 04:46:20 PM
Yup, I'll do that again tonight just to be sure, and I'll report in.
Post by: beneharris on June 03, 2023, 01:51:39 AM
Quote from: beneharris on June 02, 2023, 05:11:47 PM
Well I'll be damned. I diagnosed the transistor correctly then installed the bitch backwards. Great catch, I'm a moron.
Thanks for the help!
Post by: Govmnt_Lacky on June 05, 2023, 11:49:39 AM
Quote from: beneharris on June 03, 2023, 01:51:39 AM
It has happened to all of us at some time. Glad you got it sorted!
Post by: jimilee on June 05, 2023, 03:39:55 PM
Quote from: Govmnt_Lacky on June 05, 2023, 11:49:39 AM
It still happens to some of us.
Post by: madbean on June 05, 2023, 04:41:11 PM
Couple weeks ago I spent nearly an hour trying to debug a simple buffer on the breadboard. I had the jacks plugged in backwards.
