Projects => Tech Help - Projects Page => Topic started by: PostPaintBoy on December 31, 2011, 12:48:39 AM
Title: DC Power Jack Help Neede
Post by: PostPaintBoy on December 31, 2011, 12:48:39 AM
Ok, guys. I'm wiring up my Slow Loris and have to somewhat of an issue in regards to wiring the power supply jack. On the wiring diagram, it shows the jack connected to a battery snap which I have no intention of using. Can someone please help me by explaining what gets connected to the power supply jack? thanks in advance.
Title: Re: DC Power Jack Help Neede
Post by: jkokura on December 31, 2011, 12:56:17 AM
If you would like to eliminate the Battery Clip, all you have to do is not connect it. Otherwise everything is the same.
Post by: PostPaintBoy on December 31, 2011, 12:57:19 AM
So, where on the board would I connect the power supply to? The board has a square and circle pad. Thanks.
Post by: sgmezei on December 31, 2011, 02:12:10 AM
The square pad. If you take a look on the document, look at the single layer etching diagram. The 9v goes to R12 then D6. The circle is an extra ground pad.
Post by: PostPaintBoy on December 31, 2011, 02:25:56 AM
Now I only get the effect (a weak effect) when the input cable is only half way in?
Post by: sgmezei on December 31, 2011, 02:35:01 AM
It sounds like something is getting grounded. Can you post pics?
On the input lug, double check the wiring for the three contacts if you used a stereo plug. If you are not then you can use a mono jack.
Post by: PostPaintBoy on December 31, 2011, 05:50:15 PM
I must have followed something incorrectly because I only have two solder points on my input jack. Where is the third supposed to go?
Post by: jkokura on December 31, 2011, 06:06:41 PM
If you're not using a Battery Snap, it stays unconnected.
