Just looking around, the LM13700 IC has gotten just amazingly expensive. Tayda has it for 3.99 But digikey has surface mount for a Buck and change....Might be time to go that route.
You can get them from Mouser for $2.62 in quantities of 1.
https://www.mouser.com/ProductDetail/Texas-Instruments/LM13700N-NOPB?qs=X1J7HmVL2ZFKw9D7azZDXw%3D%3D
Jameco is another option @ $2.45 each. No MOQ
https://www.jameco.com/z/LM13700N-National-Semiconductor-IC-LM13700N-Dual-Operational-Transconductance-Amplifier-w-Linearizing-Diodes-Buffers-36-18V-570mW_192532.html?CID=GOOG&gclid=Cj0KCQjwyt-ZBhCNARIsAKH1175i4uGLQGu7eMlh3zTVfSJZSZS0VLZcJkrV0_ZxpwzsYZ9LyWEv8_saAvpiEALw_wcB
Quote from: pickdropper on October 01, 2022, 09:31:51 PM
Thank you sir. I think I'm gonna go with both through hole and surface mount footprints, I've been experimenting with a way to do that. I think I've got it figured out.
Quote from: jimilee on October 01, 2022, 11:49:45 PM
Best of both worlds.
Good plan. David at effectslayouts did this on the pulsar tremolo of mine he traced. His board has a thru hole for the CA3080 and smd pads on the backside for the 13700. When I found out that TH lm13700 were EOL I stocked up on more than I thought I would ever need from jamesco at 1.25 a piece. What's next, standard dual opamps?
Sent from my Pixel 5 using Tapatalk
Not as long as GM is still putting stereos in encono-s***boxes.
Barry at guitarpcb has them on sale!
It looks like I got out of the hobby just in time. Now the only thing I still occasionally build are kits, so no more sourcing hassles.
