General => Open Discussion => Topic started by: gordo on June 15, 2022, 01:57:28 AM
Title: Has anyone checked out Aion's power converter scheme on their preamps?
Post by: gordo on June 15, 2022, 01:57:28 AM
This is pretty cool by my standards, maybe it's been around for a while.  If you check out any of Kevin's new preamps he has a DC-DC converter module that is a solder-in block.  This is after the fact from his Lab Series preamp project but I've ordered a few spares just to monkey with retroing the power setup in the L5-pre so I can use it in a standard power supply setup.  The AC adapter was my biggest bugaboo with the board till I tried my Yamaha Stomp series power supply, and then the Voodoo Lab AC equivalent to sort out my problems.
If I'm successful I'll post a retrofit.  I think that was a major drawback to the L5 pre, although I believe it was a commercial success.  I've never used mine in a live setup just because the power is a pain in the ass.
Title: Re: Has anyone checked out Aion's power converter scheme on their preamps?
Post by: Bio77 on June 15, 2022, 02:54:51 AM
That sounds cool.  I'd be interested to see the results.
Post by: Drew Hallenbeck on June 15, 2022, 11:35:00 AM
Might work out okay but doesn't the Lab Series arrangement end up with a +/- 15v supply?
Post by: Aentons on June 16, 2022, 01:26:03 AM
I just looked at it and those dc-dc converters are over $10 a pop. It seems a bit expensive for what it's trying accomplish. Cool idea to get just the right voltage, but not sure I'd want to go that route
The PP2+ and Trutone CS series supplies will output 12V on their ACA outputs. So that and something like the TC7662B like the VFE pedals use seems ideal
Post by: Aentons on June 16, 2022, 02:53:57 AM
Quote from: Drew Hallenbeck on June 15, 2022, 11:35:00 AM
I just checked  the doc on this and yes, that does seem to be the case. I didn't realize it uses a 9v AC adapter to get +/-25v and then regulates down to +/-15v. It seems like 18v supply into a 15v regulator plus an inverter would have been easier
Sorry Aion, not trying to go negative on you, just reporting my curiousity ;D
Post by: Betty Wont on June 16, 2022, 01:49:25 PM
I'm about to build one of these, just got the parts in. I like it. Its elegant in a way.
Post by: madbean on June 16, 2022, 02:22:59 PM
I used a similar power block on the Rustbucket project. I guess the big drawback is these units are expensive and recently have been pretty hard to get. I used a different brand on the RB but the last time I looked the next availability was 2023. Other than that they seem to work really well.
Post by: benny_profane on June 16, 2022, 03:35:21 PM
One draw back to the VFE method is the current limitation, right? Those chips are rated for 20mA.
Post by: madbean on June 16, 2022, 04:07:23 PM
Quote from: benny_profane on June 16, 2022, 03:35:21 PM
Something around that. However, if you are just doing a straight bi-polar conversion (iow, DC in to output -DC) the current limitation is only for the negative rail. The positive rail is only limited by its total mA rating. But, if you are doing voltage pump and conversion on both rails then the current handling capability has to be considered for both.
Post by: gordo on June 16, 2022, 09:56:52 PM
In hindsight I sounded overly harsh in my assessment of the Aion project.  Not intended at all and I have two of them.  I would love to be able to do a DC conversion though so I ordered a couple extra modules.
I built up the Ampeg preamp that Kevin came up with and it sounds really good and quite quiet compared to my real Ampeg VT-60 which is a similar gain structure.  I also built up the Traynor TS50 bass pre for nostalgia sake. One of my fave amps (and one of the last as I downsize) is an old TS25.
Post by: aion on June 17, 2022, 11:51:43 AM
Quote from: Aentons on June 16, 2022, 02:53:57 AM
Current handling was the main issue. The L5 was on the edge of 100mA based on back-of-envelope estimation, and could very easily exceed it if someone experimented with newer opamps instead of 4558s in their build, so it wouldn't have been the right solution. But I do have a redesign of the L5 underway that uses the DC modules!
Post by: Drew Hallenbeck on June 17, 2022, 04:50:37 PM
Quote from: aion on June 17, 2022, 11:51:43 AM
Awesome! Will it still have the same control layout/drill template?
Any chance there'll be future offerings of custom printed & drilled enclosures with the nice lab series badges?
Post by: aion on June 18, 2022, 04:18:13 PM
Quote from: Drew Hallenbeck on June 17, 2022, 04:50:37 PM
Different drill template, but similar control layout overall. Top mount jacks. I'll do a full kit of it at some point, and will probably also do 'lite' kits with the enclosure and I/O module but none of the onboard components, which would be the equivalent of the enclosure runs I've been doing before.
No logo badges though... Gibson still owns the IP and they weren't exactly flattered by our homage.
Post by: zgrav on June 21, 2022, 03:04:42 PM
Did you get a pseudo-C&D letter from Gibson's attorneys that is suitable for framing?
