Hey whats up guys, I have built a few pedals with Madbeans boards, but never registered over here, but here I am ;D
Anyways I am getting my order together for the parts I need to finish this thing and I cant find any 47k5 or 475K resistors, can some one enlighten me on these? I have seen some outstanding gut shots of these and dont see any teepee's?
Also IC1 LF353N, is it ok to use LF353P?
Hey man, welcome!
If I had any of those on hand I would've sent a few your way, but I don't...Anywho, here are links from mouser.com:
47.5K:
http://www.mouser.com/ProductDetail/KOA-Speer/MF1-4DCT52A4752F/?qs=sGAEpiMZZMu61qfTUdNhG3oiHsMWFUVoRqcA6eKOZKM%3d
475K:
http://www.mouser.com/ProductDetail/KOA-Speer/MF1-4CCT52R4753F/?qs=sGAEpiMZZMu61qfTUdNhG%2fYeirsUcb7vREHoYLQxjps%3d
As far as the IC goes, the last letter is usually related to the package type. Have you looked for a datasheet?
Edit: You should be OK. I compared both datasheets and they seem almost identical on specs. Good luck!
-Kaleb
You can sub 47 k and 470 k resistors.
thanks guys
