General => Open Discussion => Topic started by: Guybrush on November 02, 2021, 06:02:14 PM
Title: This or THAT??? Decimator question
Post by: Guybrush on November 02, 2021, 06:02:14 PM
Hi gang,
I'm looking to build PCB Guitar Mania's take of the Decimator - the Noise Terminator https://pcbguitarmania.com/product/noise-terminator/
the BOM calls for a THAT 2181 chip but I'm unsure what precise version of the chip I need.
My go-to parts site, Das Musikding, lists 3 versions in the correct packaging:
THAT 2181CL08-U
THAT 2181BL08-U
THAT 2181AL08-U
These can be seen here -https://www.banzaimusic.com/search.php?mode=search&page=1&keep_https=yes
Edit: link doesn't work.
Is anyone able to point me in the direction of the one I need please?
It's the most expensive one isn't it?   ::)
Cheers!
Title: Re: This or THAT??? Decimator question
Post by: madbean on November 02, 2021, 06:12:39 PM
Those are ranked by THD, "A" being the smallest. For a guitar noise gate the C version is fine. Or split the difference with B.
Post by: Guybrush on November 02, 2021, 08:31:25 PM
Everyday is a school day here.
Thanks Bean. Much appreciated as always.
Post by: Zerro on November 03, 2021, 12:08:52 AM
Most of signal from guitar, when you play, will mask background noise between notes you play. Most annoying noise, hiss or hum, is heard when sound will decay out (if signal is not really dramatically poluted with noise). So problems with attack-decay setting is not so cruel here for staccato playing, as described. Mostly some simple semi-passive Gate would work without problem.
Here is one (enhanced) simple gate with minimal settings needs.
Post by: Guybrush on November 03, 2021, 09:10:02 AM
Super helpful. I'll take a look. Thanks!
Post by: Govmnt_Lacky on November 03, 2021, 10:50:04 AM
I believe both the original and the G-string used the 2181C version.
Post by: Muadzin on November 03, 2021, 11:36:27 AM
Quote from: Zerro on November 03, 2021, 12:08:52 AM
I've tried and built many noise gates, IMHO none can hold a candle to the Decimator. The one I haven't tried and which may be better, even though I got one is Glenn Fricker's Cockblocker.
Post by: madbean on November 03, 2021, 01:23:20 PM
Quote from: Muadzin on November 03, 2021, 11:36:27 AM
Yeah my Decimator build has never left the pedalboard. It's pretty great.
I have a noise gate idea I've been kicking around based on the THAT 4305. It's borrows a bit from the Fortin Zuul and also one of the THAT application notes. Haven't tried building it yet. I really should add something like that to the mbp project list eventually.
Title: This or THAT[emoji47] Decimator question
Post by: jimilee on November 03, 2021, 03:07:00 PM
When I was gigging, mine was always on too.
Post by: Guybrush on November 04, 2021, 08:15:44 AM
This is all good to hear. I'll be ordering the parts today.
Looking forward to seeing your noise gate Brian.
Two noise gates on one board isn't overkill is it? :)
Thanks
Post by: Guybrush on November 04, 2021, 08:38:31 AM
Ignore - duplicated post.  ::)
See below.
Post by: Guybrush on November 04, 2021, 10:51:03 AM
One more parts question please.
The BOM calls for an LF353N chip but my parts place only has a LF353P. Do I need to look elsewhere or will the N do the trick? I've read that a OPA2134 or even a TL072 can be used but thought it best to confirm with someone knowledgable here.
I've done a bit of googling but, typically, found conflicting info.
EDIT: Gahh, it also needs a MPS2222a which seem to be pretty hard to get hold of over in the UK/Europe. Can anyone advise on alternatives? A 2N2222 perhaps?
Thank you.
Post by: Zerro on November 04, 2021, 11:12:56 AM
TL072 will work with no problem. MPS2222 is general purpose NPN transistor; you can use any similar one, BC237, 238 ....
Post by: Guybrush on November 04, 2021, 12:15:20 PM
Quote from: Zerro on November 04, 2021, 11:12:56 AM
Thank you!
Still struggling finding a BC237 or BC238. I have found a listing for a BC547A that mentions it's a repalcement for the BC237A so I'm assuming that'll do the trick.
Thanks again.
Post by: Zerro on November 04, 2021, 08:51:10 PM
BC547 will work too without any problem.
Post by: Guybrush on November 04, 2021, 10:50:27 PM
Nice one.
Much appreciated. Thanks
Post by: m-Kresol on November 05, 2021, 04:13:53 PM
can you tell me where you got your THAT chips from? I built a gate a few weeks back and got some coolaudio v2181 chips via ebay that turned out to be only partially working (1/5). the others introduced more noise than they suppress. unfortunately, I did not find any sources...
Post by: jimilee on November 05, 2021, 05:42:29 PM
Have you checked cabintech? They're usually good for hard to find chips. Not sure about right now though, seems to be a chip shortage.
Post by: m-Kresol on November 05, 2021, 06:30:39 PM
Quote from: jimilee on November 05, 2021, 05:42:29 PM
thanks Jimi. Haven't used them before. Unfortunately, they are out of stock (as are all my regular suppliers). With the general semiconductor shortage, I think that XVive is on the lowest priority with fab houses at the moment. The amounts they order are likely much smaller than common semiconductor parts for automotive and so on.
Post by: czapa tranzystor 2 on November 08, 2021, 05:27:44 PM
Yes.Decimator 1 based on schematic Joao Galego.Time to move on to 2.
https://drive.google.com/file/d/0BwMWxzd7lEJ4N3c5YUwzNTJ1Tms/view?resourcekey=0-FEM2xBBkPvzVM_NIKL73cw
Post by: jimilee on November 08, 2021, 07:14:52 PM
Quote from: czapa tranzystor 2 on November 08, 2021, 05:27:44 PM
Nice, I saw that a while back. Never built it though. I figured once you build one that works, really wasn't a need / want to build another one. But, I just might do it now.
Post by: Muadzin on November 10, 2021, 10:58:04 AM
Quote from: madbean on November 03, 2021, 01:23:20 PM
You know, what I would really have liked is to have a noise gate add on board for high gain dirt pedals. Or a noise gate section as part of a high gain pedal build. That would have saved me pedal board real estate. I used to have up to 4 to 5 dirt pedals on my board necessitating at least a couple of noise gates for some of them, as I was working with loops and 1 setting to rule them all wasn't really working in my experience. Personally I think every dirt pedal should have a built in noise gate to begin with. With a possibility to bypass them if you want too.
