Projects => General Questions => Topic started by: Aentons on December 31, 2020, 05:39:32 PM
Title: Matching JFets for first time
Post by: Aentons on December 31, 2020, 05:39:32 PM
I have bread boarded a few of the jfet matcher circuits including geofex and the similar one in the nom-nom doc and I'm not having much luck. They either give me the same reading for all trannies or always measure half voltage whether a trannie is connected or not.
I tried the runoff groove tester for Vp and it seems to give each one a slightly different reading but the trannie gets really hot, really quickly.
http://runoffgroove.com/fetzertech10.png
I have seen a lot of folks over the years that have issues with the geofex one and the solution is usually just to build the similar one at runoff groove.
Also, I just have a cheap digital multimeter. Trying to match J113's
What am I doing wrong? Any tips or tricks?
Title: Re: Matching JFets for first time
Post by: jkokura on December 31, 2020, 07:32:20 PM
I built my own jfet tester years and years ago, and if I remember right, getting the transistor pinout right is very integral. Could you maybe show your setup to us with a picture, including the design you're using, and then let us help verify you have the jfet pins correct?
Post by: Aentons on December 31, 2020, 07:56:28 PM
Sorry, It's bit messy. Bottom is the one from runoffgroove. The j113 datasheet says the source and drain are interchangable
Post by: Aentons on December 31, 2020, 08:58:34 PM
I re-did it to be a little cleaner and using the nom-nom schematic.
I'm using a one spot outputting 9.45v.
With no trannie loaded I'm getting a reading -3.69v.
Post by: Aentons on December 31, 2020, 10:19:27 PM
I re-did it again with power on just one side and the source and drain swaped. Getting +3.9 with the trannie and -3.72 without.
Post by: jkokura on December 31, 2020, 10:34:41 PM
I can't quite see that there's an issue. The thing I would suggest is maybe trying my version out. I know it works, and I've attached.
The other thing might be that your JFets might be fake, which is why you're not getting good readings.
Post by: Aentons on December 31, 2020, 11:56:36 PM
Quote from: jkokura on December 31, 2020, 10:34:41 PM
Thanks, I'll try yours. All the JFets came recently from Mouser.
Post by: Aentons on January 01, 2021, 12:58:12 AM
Nope, same result. I tried wiring it a couple of different ways. I tried a new opamp this time also.
Post by: Aentons on January 01, 2021, 02:45:13 AM
The Arrow datasheet is newer (2020) and has the J113 pins listed as GSD. This is what I was using.
https://static6.arrow.com/aropdfconversion/ef7ceb2eaee61dd6eec61a61475125d8ab985b66/mmbfj113-d.pdf
I actually bought 100 of them from Mouser so I took a look at their datasheet, which is from 2001, and it has them as DSG. Wtf
https://www.mouser.com/datasheet/2/308/J113-1120625.pdf
https://www.mouser.com/ProductDetail/ON-Semiconductor-Fairchild/J113/?qs=ljbEvF4DwONIvgQL%2FiOeMA%3D%3D
Mine all have a date code of A21
Post by: Aentons on January 01, 2021, 10:29:10 PM
I measured them using the diode setting and they do appear to be DSG so that's good to know for sure.
I bought another multimeter that is advertised as having a 10M ohm impedance and tested the other multimeter. It has 1M ohm impedance, which I thought might be a factor causing the trouble.
I connected the new multimeter and initially got a -0.6v reading. Great! But then, I disconnected my leads and then reconnected, and now it back to about 3.8v. not sure what the deal is...
Post by: jimilee on January 01, 2021, 11:58:01 PM
Measure the jfets using the dc voltage setting, that's what I do.
Post by: Aentons on January 02, 2021, 12:42:18 AM
Quote from: jimilee on January 01, 2021, 11:58:01 PM
I have been using the dc volt setting for the matcher circuit. I was just using the diode setting to verify which pinout the j113 uses because of the datasheets that seem to conflict
Post by: jimilee on January 02, 2021, 12:44:04 AM
Ah. I should read more closely. And you're powering the jfet matcher of course? Do mind attaching some pictures of your set up?
Post by: Aentons on January 02, 2021, 03:50:13 AM
Here are new pics of a new rebuild using the new multimeter and a TL071 and a new battery.
Trannie inserted or not it reads -3.9v. What am I doing wrong?
Post by: jimilee on January 02, 2021, 04:11:30 AM
Nothing, that sounds accurate, does another one read about the same?
Post by: Aentons on January 02, 2021, 04:20:34 AM
Ok, I figured it out... out of frustration I started pushing on the opamp in different sideways directions and finally got a reading. So I measured power directly on both the opamp legs at the same time and got nothing.  The opamp power legs were not making contact with the breadboard. I spread the legs out and added some kinks and it's fine now. Totally lame...
Post by: Aentons on January 02, 2021, 06:20:31 AM
Thanks for your help Jacob and Jimi!
Screenshot is attached of how it turned out. They matched a lot closer than I thought they would. All within -1.21 to -1.51v range
Post by: Aentons on January 02, 2021, 07:22:43 AM
Here is the distribution. Looks like there might be some matches in there.
Post by: jimilee on January 02, 2021, 03:19:31 PM
Nicely done. Those all measure relatively low, where did you source them?
Post by: Aentons on January 02, 2021, 03:29:57 PM
Quote from: jimilee on January 02, 2021, 03:19:31 PM
I got them from Mouser recently. They are pretty much right in the middle of the range stated in the datasheet which is -0.5 to -3.0v.
Post by: jimilee on January 02, 2021, 03:36:38 PM
Quote from: Aentons on January 02, 2021, 03:29:57 PM
Oh yeah, they're definitely in spec. I was thinking for phasers, that's just where my mind goes. You should have some good ones for a VFE bumblebee in there.
Post by: Aentons on January 02, 2021, 04:10:12 PM
Yep, Hopefully I'll be good for the bumblebee. The goal was mainly to get vgs off matches for the tractor beam and other future phasers but I'm not really sure if it's good/bad to have high/low values. All I know is that I've read that the lfo sweep turn-around strength is good if they match to +/- 0.02v
Post by: Aentons on January 02, 2021, 04:11:22 PM
Here are some other randoms from other sources that I measured.
Post by: jimilee on January 02, 2021, 08:50:54 PM
Quote from: Aentons on January 02, 2021, 04:10:12 PM
That's about what I look for. The tractor beam is a great phaser build. I like the reverse setting.
Post by: Aentons on January 04, 2021, 02:54:24 PM
Quote from: jimilee on January 02, 2021, 08:50:54 PM
I finally got the matched J113 set into my tractor beam and it sounds fantastic. The phasing is strong with this one :)
Post by: jimilee on January 04, 2021, 04:43:47 PM
Quote from: Aentons on January 04, 2021, 02:54:24 PM
(https://media4.giphy.com/media/Jlt69Ka6SwtH2/giphy.gif)
