General => Open Discussion => Topic started by: gordo on November 30, 2020, 11:15:21 PM
Title: Anybody heard of using Future floor polish on pedals?
Post by: gordo on November 30, 2020, 11:15:21 PM
I used to build car models when I was a kid and I checked out a few Youtube videos recently to see if the hobby was still alive.  Very much so.  The guy in the video finished off by noting that his finished build was topped off with two brushed on coats of future.  Wait, what?  So after a bit of digging apparently this is a thing.
https://www.walmart.com/ip/Pledge-Revive-It-Floor-Gloss-Restores-and-Protects-Sealed-Wood-Floors-1-Bottle-27-oz/15136693?wmlspartner=wlpa&selectedSellerId=0&wl13=5276&&adid=22222222253447853170&wl0=&wl1=g&wl2=c&wl3=480168625112&wl4=pla-295996781749&wl5=9021431&wl6=&wl7=&wl8=&wl9=pla&wl10=8175035&wl11=local&wl12=15136693&wl13=5276&veh=sem&wl18=showcase&gclid=Cj0KCQiAzZL-BRDnARIsAPCJs71djFKx312EjVlsuCjKRaCh7ifcdaI9DxdnFINzyjrtFGee-yLAF9IaAtdjEALw_wcB (https://www.walmart.com/ip/Pledge-Revive-It-Floor-Gloss-Restores-and-Protects-Sealed-Wood-Floors-1-Bottle-27-oz/15136693?wmlspartner=wlpa&selectedSellerId=0&wl13=5276&&adid=22222222253447853170&wl0=&wl1=g&wl2=c&wl3=480168625112&wl4=pla-295996781749&wl5=9021431&wl6=&wl7=&wl8=&wl9=pla&wl10=8175035&wl11=local&wl12=15136693&wl13=5276&veh=sem&wl18=showcase&gclid=Cj0KCQiAzZL-BRDnARIsAPCJs71djFKx312EjVlsuCjKRaCh7ifcdaI9DxdnFINzyjrtFGee-yLAF9IaAtdjEALw_wcB)
It's now been rebranded by Pledge.  You brush on a couple of coats over the finished pedal (I take the knobs off and avoid switches and jacks) with about an hour or two between coats.  It goes on like water, although if you get dust in it you should wipe it off and start again.  Apparently its some form of plastic that fills in small scratches and imperfections and leaves a uniform shine on the pedal.
It looks really good.  I'll do a few before and after shots because I'm obsessed with the stuff now.
Title: Re: Anybody heard of using Future floor polish on pedals?
Post by: Bio77 on November 30, 2020, 11:52:51 PM
Please do, this sounds great.  I'm using Armorall as a final treatment to mine now.
Post by: Aentons on December 01, 2020, 12:25:30 AM
Idk... It might restrict the toanz... :)
Post by: cooder on December 01, 2020, 12:56:33 AM
Back to the future, aye...? Looking forward to seeing photos...
Post by: mauman on December 01, 2020, 04:29:18 AM
+1.  It's acrylic, made to be walked on.  It's not as hard as polyurethane but cures a lot faster (24-48 hours vs. 1-2 weeks for poly.)  Alcohol will soften it, and 100% ammonia will strip it off completely without damaging a waterslide underneath which can be handy for refinishing.  Two coats 24 hours apart make a nicely glossy top coat.  Self-flattens amazingly well with no bubbles and can be applied with a cheap foam brush, but you have to work fast and avoid the temptation to retouch.  It yellows slightly with long-term exposure to UV, but it's not obvious except over a white enclosure.  And none of the concerns about humidity, temperature and VOCs that come with spray finishes.  It's well-known in modeling and rocketry circles.  Mike
http://www.swannysmodels.com/TheCompleteFuture.html
Post by: EBK on December 01, 2020, 11:58:20 AM
Sounds similar to Minwax Polycrylic but perhaps thinner.
Post by: Willybomb on December 01, 2020, 12:57:12 PM
As a hack modeller, I can tell you that a lot of people use pledge, but there are probably more who say that there are better things to use.  As a former hack pedal maker, I think there are better things to use than floor polish as a pedal finish...  I feel the same about armourall too.
Post by: matmosphere on December 01, 2020, 02:58:58 PM
Cool idea, I'm interested to see how this looks.
Quote from: Willybomb on December 01, 2020, 12:57:12 PM
As a total hack pedal builder I think that, while there are probably better things to use, sometimes you don't need the "best" finish as long as the toanz are there. Those Arion stereo delays look about as terrible as anything I can think of.. but they sound pretty decent.
I love the way envirotex works, but damn it's a pain to deal with and it's not worth all the time it takes. Etching looks great, but I can't deal with the chemicals because of my asthma. Spray lacquer can be really nice and very easy, but I don't have anywhere to spray these days. I have done Mod-Podge and it's alright but not great. I'm always up for trying new things.
Post by: mauman on December 01, 2020, 05:04:57 PM
Quote from: EBK on December 01, 2020, 11:58:20 AM
Similar,  not quite as durable but easier to apply.  I kept having trouble with brush marks in Polycrylic so I finally gave it up, I'm sure it was my lack of painterly technique.   :o  I like Minwax One-Coat Poly but it stays soft for a long time and scars easily until it cures.
Quote from: Matmosphere on December 01, 2020, 02:58:58 PM
Here's 2 coats of Pledge/Future over waterslide on a factory-powder-coated Hammond 1590xx.   The coat of arms is on a small piece of white waterslide, the rest is on clear. Mike
Post by: harryklippton on December 01, 2020, 05:16:15 PM
That does indeed look great mauman!
Post by: gordo on December 01, 2020, 05:21:03 PM
I'm getting similar results.
The pedal is old B-stock from when I was still building Laffing Dog Blue Dog overdrives.  The enclosure on the left is the worst with tape residue and some nasty scratches.
(https://www.gordomusic.com/Madbean/LDBD01.jpg)
I sanded it smooth after using Naptha to remove the tape.  We had them powdercoated and then 3 color screen printed followed by a clear coat of lacquer.  Most of the damage is in the clearcoat.
(https://www.gordomusic.com/Madbean/LDBD02.jpg)
I dipped this box and then let the runoff drip before setting on paper towel.  This is the first coat and is dry.
(https://www.gordomusic.com/Madbean/LDBD03.jpg)
Post by: mauman on December 01, 2020, 05:37:51 PM
That looks great, Gordy.  I usually go 24 hours between coats (maker says 8 hours) and another 24 hours before installing pots, etc.  If I screw up and need to retouch, I just blanket the whole surface and it blends with previous coats well.  Touch-up with a small brush doesn't blend as well.   Mike
Post by: gordo on December 01, 2020, 05:44:41 PM
I think I need to let it dry longer as you mentioned.  A recoat looks much more dull.  I'll let this one sit and hit it again tomorrow.
Post by: mauman on December 01, 2020, 06:02:33 PM
It also likes a really thin coat, I usually hold mine with the face vertical and let it drip dry for 5-10 seconds before laying it flat to dry.  A cold or humid environment (my garage right now in TX) will cloud it before it cures, so I work in the house in winter.  Smells nice, too.   ;D
Post by: Brad Hill on December 19, 2020, 06:32:24 AM
Are these inkjet or laser prints on the waterslide decals?  Just curious to know if the Pledge reacts with the ink.  Am I safe in assuming you'd still have to do mist coats over inkjet?
Post by: gordo on December 19, 2020, 02:04:08 PM
These are printed right on the pedal so not sure the ink but it's not soluble.  I've been doing the same with laser printed decals.
Post by: gordo on December 19, 2020, 03:52:57 PM
Here's one I did last night.  It's a laser decal.
(https://www.gordomusic.com/Madbean/Julia2.jpg)
Outside of the fact that I had the text too close to the knobs you can see that tightening down the footswitch knob raised the decal at the bottom.  I pin-holed it and brushed on more floor polish but can't get it to settle down.  Up around the toggle switch I was much more careful and didn't disturb it.
Still, I think it's a clean and non-smelly alternative.  I'd think if you have a sprayed topcoat on the decals you'd be fine.  The floor polish shouldn't attack the topcoat on the decal.  But then again...you're still spraying that smelly topcoat...
Post by: jimilee on December 19, 2020, 04:38:30 PM
Quote from: gordo on December 19, 2020, 03:52:57 PM
The labeling is probably my most common error. Is that like a keenly green teeth or some other funky chorus?
Post by: mauman on December 19, 2020, 05:38:11 PM
Quote from: Brad Hill on December 19, 2020, 06:32:24 AM
I use laser, haven't tried it with inkjet, I would assume you still have to mist it since inkjet is water soluble while laser toner isn't.
Post by: mauman on December 19, 2020, 05:50:38 PM
Here's one I did last night.  It's a laser decal... tightening down the footswitch knob raised the decal at the bottom...
Gordy, is that the same as laser water slide paper?  If so, have you tried baking the decal to adhere it?  The waterslide I use can take up to 300 degrees F or so, I bake it there for 30 minutes when I apply one directly over powder coat, or at 200 F when applied over spray paint (I talked to RustOleum and they said that's the max for the automotive enamel I use sometimes.)  Really helps adhesion, better than the solvent/vinegar stuff. Then I apply the Pledge, let it cure and populate the box.  Mike
Post by: davent on December 19, 2020, 05:55:47 PM
Quote from: jimilee on December 19, 2020, 04:38:30 PM
That's where the vector pak comes in handy, place the knobs on your artwork then fit the lettering to the knobs, delete the knob before printing. Then its just a matter of putting the decal on the enclosure straight.
Post by: jimilee on December 19, 2020, 06:18:25 PM
Quote from: davent on December 19, 2020, 05:55:47 PM
Yeah, that's where the lazy comes in. Ah, it'll be alright....sometimes my brain tricks me into thinking the label is way too low.
Post by: gordo on December 19, 2020, 07:07:46 PM
Honestly, I've been doing this long enough that you'd think I'd figure it out.  I'll try the knob trick though because I really only use a few different sizes.
Jimi, this one is the PedalPCB Caesar, which is a clone of the Walrus Audio Julia.  I blatantly ripped of the graphics.  It's a nice variation on the CE-2 with added blend, the option to use Sine or Triangle for the LFO, and a nice touch is being able to set the delay time (which kinda pushes it into the BF-2 flanger zone).  As long as I've been hanging around here I've never built up a PorkBarrel.  It's on the bench now and I'm looking forward to comparing them.  My original CE-2 got sold a very long time ago.
Post by: jimilee on December 19, 2020, 07:51:29 PM
Quote from: gordo on December 19, 2020, 07:07:46 PM
Wow, sounds neat. I've never built the pork barrel either (that I can remember anyway), but I did build the BYOC chorus, which sounds fantastic on bass. It started on my board the whole time I was gigging. I used it on slow songs to kind of fill space in a 3 piece band.
Post by: Bio77 on December 19, 2020, 11:51:33 PM
Damn you!  Now I have to build this one  ;D
Looking good!  8)  Do you know if the floor polish flakes off?  Pedals that I have sprayed with clear get flaky after a few month on my board.  It's pretty cool that you can put this stuff on without tearing the pedal down.  Thanks for the report.
Post by: mauman on December 20, 2020, 05:25:01 AM
Quote from: Bio77 on December 19, 2020, 11:51:33 PM
Do you know if the floor polish flakes off?  Pedals that I have sprayed with clear get flaky after a few month on my board...
I haven't had any problems with flaking and I have some that are more than 2 years old. As Gordy says, it's not as tough as polyurethane.  It also softens with alcohol and you can strip it with ammonia, but it applies better than poly.  BTW, I've also stripped Minwax polyurethane and Minwax polycrylic with 100% ammonia.  Mike
