Projects => How Do I? Beginner's Paradise. => Topic started by: mattc on September 07, 2020, 04:22:10 PM
Title: Struggling to get started with graphics
Post by: mattc on September 07, 2020, 04:22:10 PM
So I've been building pedals off and on for a long time (I started back when Bean was selling etched boards).  However, I've never done any graphics for them.  I've always used a sharpie or stamps.   I'd like to do some more interesting graphics but I'm struggling to get started.
I have a drill template in PDF (some from Bean, some from pedalpcb).  I want to pull that into a graphics program and then use that as a starting point to add graphics so that my labels and whatnot are in the right place.
Here's what I can't do.... I can't import the drill template from PDF into any graphics program without the template getting resized.  I'm happy to use Inkscape, Gimp, paint.net, whatever... I'm not looking to do fancy things, just some labels.
Here's what I'm starting with: https://www.pedalpcb.com/docs/SixStringStinger.pdf
Any suggestions on how to import the PDF without it resizing would be greatly appreciated.  I really want to make things that look nicer than just a stamp :(
Title: Re: Struggling to get started with graphics
Post by: madbean on September 07, 2020, 04:44:19 PM
Just about all the mbp projects have a drill file in psd format in the zip. I think those can be imported to Gimp. Or, there might be some preference setting in Gimp for opening pdfs that you need to change.
Post by: matmosphere on September 07, 2020, 04:48:44 PM
Check what the DPI of the pdf is. It's probably listed in the documents properties but I think where it's listed changes from program to program.
Open a new file in your graphics program and make sure the DPI is set to the same.
That said, my solution to this is a little more quick and dirty. I do the measurements as best I can from the enclosure that I've already drilled and use that as my starting point. I keep everything simple, no rotation indicator lines or anything, that way if stuff is a little off here or there it's not very noticeable. Then when I go to print sometimes I'll print a couple that are sized slightly larger or smaller and just see what works best
Post by: davent on September 07, 2020, 05:11:42 PM
You should be able to import the pdf's into Inkscape, how i did it all the time. If they do resize you can use Inkscape to correct the sizing.
Get the Vector pack of pedal parts, its great for helping to visualize the finished design.
https://guitarpcb.webs.com/apps/forums/topics/show/3936591-pedal-vector-art-pack
If you have an already drilled box you can scan that, open it in Inkscape then do your design over that.
There are a few things i couldn't work around with Inkscape with graphic manipulation, GIMP easily took care of those and then taken back to Inkscape to finish the projects.
Post by: jimilee on September 07, 2020, 09:56:54 PM
Photoshop has always worked for me.
Post by: mattc on September 09, 2020, 12:36:15 AM
Thanks all.  I got a basic design made for a green bean.   Now to figure out the water slide decal.....
Post by: gordo on September 09, 2020, 03:46:57 AM
Sniff around here for decal tutorials. Lots of info. Keep an open mind because decal stock from different sources acts differently. Nothing major, you just have to adjust your touch and soak times.  Finishing pedals is the most difficult part of the build for me but there are a ton of wizards amongst us :-)
Post by: Thewintersoldier on September 10, 2020, 01:49:47 AM
I tried a couple programs and liked paint.net for easy of use and low learning curve. Its got a decent feature set but not as expansive as adobe photo shop but I keep it pretty simple. I have templates set up for various size enclosures and use the vector pedal pack as well. This video was a good tutorial that gave me a basic workflow and starting point.
https://youtu.be/WXnGe68dGCY (https://youtu.be/WXnGe68dGCY)
Post by: madbean on May 14, 2022, 06:23:54 PM
Quote from: Giannaapom on May 14, 2022, 06:06:15 PM
I tried to work with graphics, I don't want to anymore
Hobby store - small ink stamps - Stazon ink.
Post by: G.G. on May 18, 2022, 12:34:57 PM
mattc,
Not sure about other apps, but if Photoshop is overkill for you maybe have a look at Affinity Photo. It's around $50 and has a similar feature set. To open a PDF in Affinity: Choose Open and select your PDF file. You'll get a dialog box like this where you can select the page that has the drill template. Select your DPI (dots per inch), I usually do 300 DPI. Your drill template will open and be ready to print at 300 DPI. Do your graphics in the file, then when you're ready to print just make sure it's set to print at 100% and not scaling your image up or down. Let us know if you need more help, we all have gone through this.
~Gray
