Projects => General Questions => Topic started by: jjjimi84 on April 18, 2020, 06:12:12 PM
Title: Sagan Delay 2.1 Modulation Question
Post by: jjjimi84 on April 18, 2020, 06:12:12 PM
I recently built the sagan delay and love the delay sounds but before i can call it complete and do a build report, I have to double check with all of you about the modulation from the lfo.
It is crazy, like over the top sea sick warbly. The subtle setting is almost off and otherwise it is really overpowering.
Is this correct? Is it supposed to be like that? Is there a way to reduce it?
Thanks for any help. It sounds really cool with the PedalPCB Organ Grinder in the loop
Title: Re: Sagan Delay 2.1 Modulation Question
Post by: jimilee on April 18, 2020, 06:51:33 PM
Sounds like what I'm getting.
Post by: diablochris6 on April 19, 2020, 01:22:21 AM
More or less, yes, that's the way it works. If you want to make it more subtle, you can always try a different color LED that doesn't trigger the LDR as drastically. You could also bend the LDR so it doesn't directly shine on the LDR. I like turning mine only about a quarter up.
Post by: jjjimi84 on April 19, 2020, 04:13:08 AM
Quote from: diablochris6 on April 19, 2020, 01:22:21 AM
Well I am happy that I built it correctly. I will mess with the ldr and led combination and see what I come up with.
Chris you made an incredible circuit, the delay is amazing and the preamp is just killer.
Post by: diablochris6 on April 19, 2020, 05:37:48 AM
Glad you enjoy it! I let the LFO get wacky because I wanted to give folks the option to get super weird. As you can tell with the number of knobs on my builds, I like options!
Post by: jimilee on April 19, 2020, 01:18:31 PM
Quote from: diablochris6 on April 19, 2020, 05:37:48 AM
You can never have too many knobs and switches. The Duelin Herbies gets close though...
Post by: Timko on April 20, 2020, 03:48:09 PM
I haven't built the Sagan Delay 2.x yet, but the 1.x had the same type of thing when you use an external modulation board.  I originally didn't have a switch to turn modulation on/off on the build but ended up replacing the drykill switch with a modulation on/off.
That said, you come up with some WACKY sounds when you turn on the modulation.  I'm not sure how to use them, but they're definitely unique.
