Projects => Tech Help - Projects Page => Topic started by: ckim715 on September 27, 2019, 03:33:08 PM
Title: Man, this Total Recall just keeps having glitches
Post by: ckim715 on September 27, 2019, 03:33:08 PM
Got the bias issue solved, got the regulator issue solved, now it's a really really weird thing:
Even when the pedal is not powered, it passes signal when engaged. It is very faint, but it's there. I have it wired true bypass. I am assuming I have a short somewhere on my switch, but wanted to see what you guys thought. More digging to follow...
Title: Re: Man, this Total Recall just keeps having glitches
Post by: Scruffie on September 27, 2019, 03:40:20 PM
Sounds like a job for a continuity tester, probably just a loose strand of wire.
Post by: ckim715 on October 01, 2019, 03:53:58 PM
Continuity test shows that there isn't a short on the switch...anywhere else it could be?
Post by: ckim715 on October 06, 2019, 03:31:01 PM
Hm. Wondering if this is normal function. Does anyone else have signal pass through their true bypass wired Total Recall when there is NO power, but pedal is engaged?
Post by: madbean on October 06, 2019, 03:48:05 PM
Quote from: ckim715 on October 06, 2019, 03:31:01 PM
It's not uncommon to have some signal through a circuit when it is unpowered. Look at the schematic - with no power there is an AC path from input to output through a series of resistors.
