Hi all,
I'm building a Spackler and I have a quick question. The 22pf caps in the feedback lop of the opamps actually creates a slight treble boost correct? So if I replace them with 47pf caps I'll simply be dropping the freq of the boost down a bit as far as I can tell. Does anyone know how much change it will be? I'm all out of 22pf and I can't find any locally and I hate to order just 2 caps from SB - I've got a pile of 47pf and there's not room on the board to double up the caps..
Thanks all!
actually, capacitors in the feedback loop of an opamp act as a low pass filter. if you don't have 22pf, 47pf will work fine.
Cool - I've got a special enclosure baking right now for this one. I'll post her when she's done.
