Projects => Build Reports => Topic started by: Ettore_M on September 29, 2011, 08:13:40 PM
Title: Distroyer +
Post by: Ettore_M on September 29, 2011, 08:13:40 PM
That's my take on MXR Distortion Plus. I had built one before a few months, but i didn't like it. So I took it apart and rebuilt using Dragonfly's veroboard schematic, but I couldn't make it work. I checked it with a schematic fron tonepad.com, and I found that it misses a trace cut to the right of the 1u electrolytic cap. I fixed that and now it works great!
I'm pretty happy with the result. The distorted sound is pretty good and with enough gain. But it's a little more "trebly" for my taste (Maybe someone could help me change something in the schematic: http://www.tonepad.com/getFile.asp?id=115 (http://www.tonepad.com/getFile.asp?id=115) to make it more "bassy" ).
I hope you like it!
Hector
P.S. Handpainted with a sliver sharpie (not a great look, but I like it). The two holes remaining are for the LED and a SPDT switch for LED diode clipping..
Title: Re: Distroyer +
Post by: nzCdog on September 29, 2011, 08:41:39 PM
Hey Hector, nice work and congrats on getting it going! I'm diggin the sharpie action ;)
Where'dya get that enclosure?
Post by: Ettore_M on September 29, 2011, 09:12:58 PM
I got that from an electronics store.. Here in Greece is difficult to find Hammond-like enclosures :-[. This was the closest thing ::).. But now I'm thinking to make my own boxes like this: http://www.geofex.com/Article_Folders/steelstud/steelstud.htm (http://www.geofex.com/Article_Folders/steelstud/steelstud.htm)   ;)
Post by: stecykmi on September 30, 2011, 12:57:05 AM
nice build, the Dist+ is a pretty cool circuit. my first build was a Dist+ kit from BYOC years ago.
If you want to decrease the treble a little bit, add a capacitor in the feedback loop of the opamp. that's C5 on the tonepad layout (you can also increase the value if you already have one there). i suggest a pretty small value like 50pF or so.
Post by: chromesphere on September 30, 2011, 02:42:57 AM
Hi Hector,
i recorded a video of my distortion plus a while back and put it up on youtube and funny enough i actually talk about the, over the top, treble.  I found if you turn the treble way down on your amp, like, half of what you would usually have it set to, it's quite usable. Took me a while to work that out, as i thought that just how it was suposed to sound, hollow and trebly. Once the treble is balanced it sounds pretty good imo!
Heres the clip:
http://www.youtube.com/watch?v=maSkDb5pP24&feature=channel_video_title
Hope it helps, and good luck!
Paul.
Post by: jtn191 on September 30, 2011, 06:59:43 AM
I've been eying Dist + ever since I found out it was responsible for some of my favorite sounds (probably on guitar at 0:20 on right channel http://www.youtube.com/watch?v=hvZseXEqdss&ob=av3n )
Neat enclosure, it looks geeky or military like. I swear my next box (or two) will be a Lego one once I get back into building  ;)
(http://www.tymguitars.com.au/prod/wp-content/uploads/P1050066-300x258.jpg)
Post by: Ettore_M on September 30, 2011, 08:27:10 AM
Quote from: stecykmi on September 30, 2011, 12:57:05 AM
Thanks! The Distroyer was my first build too. That started my addiction with DIY pedals, although I was dissapointed with it in the beginning.
I already have a 10 pF (I think..) like the schematic. I will try that and other values, until I take the sound I  want. So, thank you for that!
Post by: Ettore_M on September 30, 2011, 08:34:49 AM
Quote from: chromesphere on September 30, 2011, 02:42:57 AM
Hi Hector,
Heres the clip:
Paul.
Thanks, Paul! It was really helpful to hear another DIY Dist +, so I can compare it with mine. I can say that they sound almost the same!
I tried the same thing you say with my amp and tone control pot on my strat and I have better results. But that "destroys" my clean sound. So it's not so practical. I want a more permanent solution!
Post by: chromesphere on October 02, 2011, 10:32:56 PM
Hi Hector,
The only thing i could think of, in a live situation would be to use an EQ pedal.  Or maybe as a future build you could build one?  Also, look around for a mod for the dist+ to add a tone control to the circuit (might be too late for that though).  I'm sure i've seen the discussion come up in the past.  DIYSB forum has the dist+ as a beginner project.  This would be the best place to look / ask about a tone control.
Hope it helps!
Paul
