General => Open Discussion => Topic started by: gordo on March 18, 2018, 11:21:30 AM
Title: Your favorite pedal you've built?
Post by: gordo on March 18, 2018, 11:21:30 AM
This will open up a fire storm but what's your favorite pedal you've built?
I've pondered this question for ages and it boils down to the "must have" pedal on my live board.  The weird part is that it's a "non-effect-is-this-thing-on" but it makes my whole rig.
If been thru a million compressors and barring the Cali (way out of my budget but ultra cool) I've never played a comp that beats this thing.  The MBP 4:1 comp is a variation on the Afterlife variation on the Flatline.  It has a few key points that make it my fave:
That said, it's not really an effect.  My double-neck sounds crazy cool thru this but not in a Byrds sort of sound.   It drives my overdrive pedals nuts and sounds great behind a booster but it also changes the tone, width, and attack of those overdrives in a way that makes it almost an A/B switch on them.
My only issues were that as a gain changer it would be audible if I forgot to engage it before my delay (Nova) which I almost always do.  You'd get a click...click...click..click thru the FOH.  And a tongue lashing from the sound person.  So what to do?  Add a relay bypass.  But in a "G" enclosure?
Roll back to the Christmas PIF's and I was lucky enough to score a Soup39 enclosure.  It was a "G" and I had no idea what to put in it.  It was the coolest pattern though. The 4:1 would be a perfect candidate because I didn't have to rely on labels.  This is a set it and forget it pedal for me.  I had a 1776 relay bypass waiting for a relay and it dawned on me that I could float the 1776 board under the 4:1 board.  If I'd had the foresight to not socket the ATTiny chip it would be invisible but it still worked.
Drilled out the enclosure and figured out where I could double side tape down the relay and wire it up for power, lights, jacks, and switch.
(http://www.gordomusic.com/Madbean/4-1-01.jpg)
(http://www.gordomusic.com/Madbean/4-1-02.jpg)
Then layer in the effect board.  Pretty easy at this point, just have in/out/gnd/9v connections.  I have the luxury of making sure that the bypass and LED portion work correctly first.  BLMS knobs, switch, and jacks.
(http://www.gordomusic.com/Madbean/4-1-03.jpg)
(http://www.gordomusic.com/Madbean/4-1-04.jpg)
Title: Re: Your favorite pedal you've built?
Post by: HamSandwich on March 18, 2018, 02:06:08 PM
You may have sold me on the 4:1 ;D really cool enclosure too. Looks like liquid marble.
I don't have a story behind it, but my favorite is the lunar module deluxe. Such a versitile box, I hate to label it a fuzz as it definitely covers distortion and drive sounds. I've used it for years and haven't gotten tired of it.
Post by: junkemail86 on March 18, 2018, 02:14:48 PM
Agreed, the lunar module is amazing.
I'd have to go with the BSIAB II or Pinnacle personally
Post by: alanp on March 18, 2018, 03:14:45 PM
Doppelganger.
Post by: juansolo on March 18, 2018, 04:53:23 PM
Supernature (Jumbo Tonebender). If I could have only one pedal, it'd be that.
Post by: sonnyboy27 on March 18, 2018, 05:16:39 PM
It's cliche, but my Klone hasn't left my board since I built it. But I'm gonna have to check out the 4:1 now cause I love my Rothwell Love Squeeze but it sounds like the 4:1 has a little more in terms of options.
Post by: Willybomb on March 18, 2018, 09:56:32 PM
My Leviathan (boost, zendrive/englishman, plexi) hasn't left the board.  Covers so much ground in the cover band situation.
Post by: Strategy on March 19, 2018, 12:29:55 AM
I've built mostly really exotic pedals, but the one thing that's always in the chain is Red Llama/Hot Tubes. Bulletproof, compact + versatile for any kind of music or input signal (guitar, rhodes, synth, drum machine, miscellaneous).
Post by: EBK on March 19, 2018, 12:37:34 AM
My Wayne Kirkwood One Knob Squeezer (now pedal design five on the THAT Corp. pedal page).  I added a bicolor bargraph display that tells me exactly what it is doing to my signal at every moment, and I'm happy to leave it on 100% of the time.
Post by: chromesphere on March 19, 2018, 01:40:01 AM
Tough question.  So hard to choose just one but I would probably go with my prismatic reverb (BTDR-2) because I like to play ambient and my amp overdrive (bad cat) is kind of hard to beat!
Post by: thesmokingman on March 19, 2018, 05:13:04 PM
I think my favorite is the fuzz factory. It isn't particularly special or complicated but it was the first effects pedal I built so I suppose there's some sentimental things going on there.
Post by: dan.schumaker on March 19, 2018, 05:37:41 PM
My favorite that I have built is Brane's Voodo Vibe
Post by: matmosphere on March 19, 2018, 07:25:26 PM
I don't think I could pick just one.
I really like my Bearhug comp, and my Jawari. But I use the demo tape Fuzz and my stomptown Muff almost constantly.
Post by: Aleph Null on March 19, 2018, 09:21:31 PM
Overall, my Astro(not): http://www.madbeanpedals.com/forum/index.php?topic=25287.msg246140#msg246140
It can be whacky in a lot of settings, but it can also be set for "instant lead tone". It's a surprisingly good sounding circuit once you learn how to set it. I am also very pleased with the aesthetics of the build.
Post by: Boba7 on March 20, 2018, 12:10:00 PM
Aleph > That's seriously one of my favorite builds ever! Beautiful beautiful work.
My personal favorite is my Lofi Machine that I sold to a musician who was really insistent. I will have to build myself another one someday. It was very inspiring to play.
How it sounds : https://soundcloud.com/user-322140065/lo-fi-machine-subtle-detune-and-noise
How il looks :
(https://i.imgur.com/biMOWAt.jpg)
Post by: Timko on March 20, 2018, 02:14:53 PM
This one is a tough question, but for me, it's probably the Multiplex.  It's the delay that always makes its way back to my board.  It's so easy to dial in good sounds too, and it's the pedal that most people ask "wtf is that."
Post by: matmosphere on March 20, 2018, 03:08:28 PM
Quote from: Boba7 on March 20, 2018, 12:10:00 PM
How il looks :
Nice! It sounds great.
I vaguely remember a thread about that thing.
What is in that box?
Post by: storyboardist on March 20, 2018, 04:06:28 PM
I always come back to the Speaker Cranker. Always bugs me a little that such a simple circuit sounds so good, but it almost always ends up on.
(https://s26.postimg.org/g9738djvt/Speaker_Cranker.png)
Post by: Aleph Null on March 20, 2018, 04:13:54 PM
Quote from: storyboardist on March 20, 2018, 04:06:28 PM
The speaker cranker is definitely in my top five. It was the pot of gold at the end of my overdrive quest.
Post by: blearyeyes on March 20, 2018, 05:17:21 PM
Quote from: EBK on March 19, 2018, 12:37:34 AM
EBK gain reduction LED ladder is interesting.
Post by: Boba7 on March 20, 2018, 06:03:18 PM
Quote from: Matmosphere on March 20, 2018, 03:08:28 PM
It's a comp into a Pitch Pirate (with a dark position) into a switchable bitcrusher (Sonic Reducer by Parasit studio)
Initially the comp was a mosfet comp from Circuit Salad, but then I put in Mictester really cheap compressor.
http://www.madbeanpedals.com/forum/index.php?topic=22701.0
Post by: Droogie on March 20, 2018, 06:09:23 PM
Can't narrow it down to one fave, but Aion's L-5, Jason's Cascadia and Bean's 2014 Kingslayer are never left at home.
Post by: bamslam69 on March 20, 2018, 11:57:11 PM
Still relatively new to this game. But the LPB-1 I built last month is fun, and as I completed it in under 24hrs, I'm pretty happy.(https://uploads.tapatalk-cdn.com/20180320/d261268d8dbc275bf27d05c0b4f464dc.jpg)
Sent from my SM-G900I using Tapatalk
Post by: LaceSensor on March 21, 2018, 08:15:42 AM
Mine has the be the Aeon Blueshift / Boss Dimension C
Ive lusted after that proper 80s stereo chorus for so long, and was such a pleasure to be able to build it for myself.
Post by: madbean on March 22, 2018, 01:24:34 AM
It's really hard for me to pick my own personal favorite but I'd say this one is close:
(http://www.madbeanpedals.com/builds/gallery/RangeMaster1.jpg)
Reason being is 1) it's simple 2) it sounds great and 3) my artwork/etch/enclosure design is nearly perfect (yes, I am humble).
Post by: jimilee on March 22, 2018, 01:46:44 AM
I'd have to say the humor user I built. 4 effects with effects order switchers between each effect, I could literally reverse the order of the whole pedal, it was cool.
Post by: Mich P on March 22, 2018, 07:34:52 AM
For me it is the Mind Bender.
Post by: drezdn on March 22, 2018, 02:29:29 PM
Probably my Magnus Modulus, but I could see a multiplex taking over that spot in my heart eventually.
