How do I add simple in/out/ground/etc. pads in Eagle CAD? I'm in the schematic view and I can't seem to find any in the madbean eagle library. There are In/Out ones in the supply pins folder but it seems that they do not attach an actual physical pad when I export to the board layout view. In the madbean library description for the In/Out supply pins it says:
"obsolete: use Mark instead and label net
output label without circuit board terminal/pad"
Any suggestions? As always thank you in advance
You have two options for that, in MBP_2017_v3 library use
a) BYP.2 option in supply pins directory.
b) use any pad in PADS. directory and rename it as in, out, 9v etc..
Got it, thanks!
I think I'm still using the 2015 library, link me to 2017 zip?
http://www.madbeanpedals.com/forum/index.php?topic=25194.0
Thank you! :)
