General => Open Discussion => Topic started by: jimilee on June 17, 2017, 04:21:19 PM
Title: Four track recorder
Post by: jimilee on June 17, 2017, 04:21:19 PM
Does anyone have an old 4 track recorder or the like? I found some of my brothers old recordings and would really like to hear them. You can on a regular tape player, I know, but some of the tracks end up in reverse.
Title: Re: Four track recorder
Post by: AntKnee on June 17, 2017, 05:43:02 PM
Found this locally. I'm happy to play middle man for you if you want to get it.
https://austin.craigslist.org/msg/6122704670.html
Post by: jimilee on June 17, 2017, 07:13:57 PM
Hey, thanks for the offer, that's more than I'd like to spend and probably more than a 4 track should cost, so they still make cassettes? If I was going to use it to record it might be worth the extra money though.
Post by: selfdestroyer on June 17, 2017, 07:17:49 PM
Jimi, you are actually going to be seeing an arch with prices for tape 4-tracks. They are getting popular again for the lofi heads out there. I used to find Fostex and Tascam's all day on eBay and CList for under $50 but it's been getting a bit harder. On top of this, the belts don't hold up well over time for my experience and you may need to find replacements. Something to keep in mind.
Post by: wgc on June 17, 2017, 08:09:12 PM
I still have my old fostex. (I still need to locate my old song demos since I'd like to transfer them to my pc.  Probably at my moms.) If you're not in a hurry I can try to help. Send a pm.
One thing you can try short term is using a Walkman, record L & R out to two tracks in audacity or similar. Flip the tape, record the backwards output to two more tracks, and then use the reverse edit on the backwards tracks.
You'll have to sync things up manually but with a little effort it's doable.
Post by: pickdropper on June 18, 2017, 04:34:01 AM
Next time I'm at my folks' house, I'll see if my old 424 is still there.  I still have some tapes squirreled away that I should archive at some point, but I'd be happy to lend it to you if you cover the shipping costs (and if I still have it, of course).  That way, you could mix those tapes down and put them in a more stable format.
Post by: nzCdog on June 19, 2017, 02:07:12 AM
Dang!  We had one of those Tascam's at high school.  That brings back lots of memories  :)
