Projects => Tech Help - Projects Page => Topic started by: Billy_Vegas on June 11, 2017, 09:46:55 PM
Title: WEENER WAH (1st version): Use the output buffer as buffered bypass
Post by: Billy_Vegas on June 11, 2017, 09:46:55 PM
Hi guys, hi Brian. Is it possible to use the output buffer of the older version of the Weener as a bypass buffer? Here's the building doc:
http://www.madbeanpedals.com/projects/WeenerWah/WeenerWah.pdf (http://www.madbeanpedals.com/projects/WeenerWah/WeenerWah.pdf)
Title: Re: WEENER WAH (1st version): Use the output buffer as buffered bypass
Post by: drolo on June 16, 2017, 11:10:29 AM
certainly possible, you would need to cut the trace between the output of the wah and the input of the buffer (between C3 and C7) and insert your bypass switch there
