Projects => Build Reports => Topic started by: AntKnee on March 15, 2017, 04:00:12 PM
Title: Chorus - Pork Barrel
Post by: AntKnee on March 15, 2017, 04:00:12 PM
After deciding to just go with 9v operation, here's my finished Pork Barrel. I used one of the new stomps with the led washer. Looks really cool and the switch feels like it is of good quality. I went with off board pots so I could space them to look better on this enclosure and so I could use large knobs. I love how it turned out and how it sounds. I compared it to my MIJ CE-2, and it is 99% spot on. The knob settings even match up almost perfectly. I'll be using this a lot!
Try to ignore the little bit of velcro fuzz below the input label. It's not a blemish.  ;)
(https://dl.dropboxusercontent.com/u/13215910/Web%20Images/pork%20barrel%20a.jpg)
(https://dl.dropboxusercontent.com/u/13215910/Web%20Images/pork%20barrel%20b.jpg)
(https://dl.dropboxusercontent.com/u/13215910/Web%20Images/pork%20barrel%20inside.jpg)
Title: Re: Chorus - Pork Barrel
Post by: cajone5 on March 15, 2017, 04:26:10 PM
LOVE this!  great work!
Post by: wgc on March 15, 2017, 06:12:23 PM
Awesome!
Post by: mrclean77 on March 15, 2017, 06:41:52 PM
Super slick inside and out! I would not have thought about the pots if you didn't mention it - or maybe I woulda guessed you just made the legs streeetch to make it work - nice job on that part, too!
I need to locate/open the ol' wallet for some different chips to try - I do not have an original to compare to, but every time I see a PB thread, I make sure to note it ended my chorus search.
Post by: AntKnee on March 15, 2017, 07:10:21 PM
Thanks, everybody!
Quote from: mrclean77 on March 15, 2017, 06:41:52 PM
Well, I say offboard, but I actually used solid leads on solder lug pots. The location isn't that much different from pcb mount, but if you mount this in a 1590b, you can't use large knobs or they hang over the edge of the pedal. So, my solution was more space between pots, bigger box, bigger knobs.
Post by: mjg on March 15, 2017, 09:06:04 PM
Ooh, where do you get the glowing ring around the stomp switch. That is awesome.
Post by: lego4040 on March 15, 2017, 11:09:21 PM
Awesome job all around. Did you paint the enclosure? And yes, where did you get that led stomp switch
Post by: CODymmoT on March 16, 2017, 12:08:27 AM
That is super clean! Enjoy it's a great pedal.
Post by: AntKnee on March 16, 2017, 01:30:59 AM
Thanks for the kind wordz.
Footswitch here:
http://www.ebay.com/itm/3PDT-Foot-Switch-with-Blue-LED-Ring-Solder-Lugs-True-Bypass-BEST-QUALITY-/262785115427?hash=item3d2f36a523:g:4OwAAOSwt5hYZr3B
He may have sold out, probably thanks to this forum.
Post by: jimilee on March 16, 2017, 01:46:21 AM
That's really nice.
Post by: gordo on March 16, 2017, 03:12:28 AM
That's just beautiful. Quite a bit closer to what the switch looks like. It's hard to photograph. It doesn't go dark at the edges like yours and my photos show. Mine much more than yours. Terrific build in and out.
Post by: AntKnee on March 16, 2017, 03:17:20 AM
Quote from: gordo on March 16, 2017, 03:12:28 AM
I tried a few LDRs and ended up using a 1k. I thought it looked best. What did you use on yours?
Post by: Boba7 on March 16, 2017, 02:57:28 PM
Wow, what a great looking pedal!!
Post by: flanagan0718 on March 18, 2017, 01:53:08 PM
Super sharp build. Inside and out.
Post by: lars on March 21, 2017, 02:42:30 AM
That looks like a production pedal. Outstanding job!
